Outdoor GFCI Won't Reset - Electrical - DIY Chatroom Home Improvement Forum
Old 03-23-2012, 03:42 PM   #1
Outdoor GFCI won't reset
My outdoor GFCI won't reset. Its been there several years so I know its wired correctly. It apparently tripped during during a rain storm the other day, its been raining for almost a week. Its not tripped at the breaker box and the LED on the GFCI is illuminated but it won't reset so I assume it was damaged since I can't find any other apparent cause. Should I just wait for it to try out or change it? I know how to change it but how do I know I have the electricity to it turned off at the breaker box (of course, I don't know which specific circuit breaker controls that outlet) since the outlet is already dead?
dadret is offline   Reply With Quote
Old 03-23-2012, 03:55 PM   #2
Getting There
MecGen's Avatar
Good chance your GFI outlet is defect, , you might want to call a serviceman.
And I am not an electrician....
MecGen is offline   Reply With Quote
Old 03-23-2012, 03:58 PM   #3
joed's Avatar
Rewards Points: 11,596
The GFCI receptacle or one of the ones it controlls probably has water in it.
Old 03-23-2012, 05:17 PM   #4
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
What year was the house built?
Old 03-23-2012, 06:08 PM   #5
Electrical Contractor
jbfan's Avatar
Rewards Points: 144
On some brands of gfci, the light will come on win it is tripped, and some will come on when it is time to replace it.
jbfan is online now   Reply With Quote
Old 03-23-2012, 07:47 PM   #6
Hell of a fella
Rewards Points: 27
if the led trip/replace light on the receptacle is on...it will turn off when you kick the breaker off for a swap-out.
DrumBum is offline   Reply With Quote
The Following User Says Thank You to DrumBum For This Useful Post:
oh'mike (03-27-2012)
Old 03-23-2012, 07:55 PM   #7
k_buz's Avatar
This, something plugged in to an outside outlet has a problem, or depending on the year the house was built, the bathrooms or laundry could be on that GFI as well and have something plugged in causing the problem.
Old 03-24-2012, 06:40 PM   #8
I figured out which breaker turns off the GFCI and I'm now sure its just a defective GFI since on the line side of the outlet (from the breaker box to the switch) I have power but nothing from the load side to the outlets beyond the GFI. When I turned off the breaker I lost power to the outlets on the line side before the outdoor GFI. SO I'll just change it and see what happens. Thanks for all your comments.
Old 03-24-2012, 07:26 PM   #9
k_buz's Avatar
You don't have power on the load side because the GFI is tripped. Did you take the outlet out and test the terminals? Or did you leave the GFI in and test the outlet itself?
If you are testing the terminals (on the side of the GFI) you will have power as long as the breaker is turned on. The GFI won't control those even if the GFI is tripped.
Do this, take the wires off the load side of the GFI and try resetting it. (The load side wire should be located on the top two terminals...one on each side). If the GFI holds, you have a problem down the line. If it trips you probably have a bad GFI.
Old 03-24-2012, 07:28 PM   #10
k_buz's Avatar
Is this GFI controlled by a switch? If so, make sure the switch is in the on position when you try to reset it. Newer GFI's won't reset without power to it.
Old 03-24-2012, 08:23 PM   #11
joed's Avatar
Disconnect the LOAD wires and turn the power back on. Try to reset the GFCI. If it resets then there is a fault somewhere on the load wires.
Old 03-24-2012, 11:45 PM   #12
Missouri Bound's Avatar
...nd GFCI's will not reset unless there is power to them.
Do you want it your way or the right way?
Old 03-27-2012, 07:30 AM   #13
I changed the GFI the other day and now everything works fine. Turns out that the GFI is at the end of a circuit which probably explains why the outlets in front of the switch still worked. There are no wires coming from the load side - its just a receptacle. Also, the GFI that the builder put in was not an outdoor rated outlet.
Complete ECM reset procedure ukrkoz Automotive Repairs 2 12-16-2011 08:29 PM
Water heater reset is tripping. rjniles Plumbing 7 11-24-2010 09:15 AM
Boiler needs to be reset Chris12047 HVAC 8 11-12-2008 03:28 PM
Oil burner won't kick on, have to push reset edski HVAC 4 11-06-2007 03:04 PM
GFCI wouldn't reset, now it will sherlock Electrical 4 10-18-2005 11:13 AM
