Outdoor Floodlights - Electrical - DIY Chatroom Home Improvement Forum
Old 03-12-2011, 05:08 PM   #1
Rewards Points: 165
Outdoor Floodlights
I want to run new wiring for some outdoor lights, but have hit a snag in the planning phase. I want to put a flood light on the outside of a support column on my back porch. I want the light to face out and illuminate the back yard. The column is actually a metal post (possible a lolli-column) boxed in with woood, so I think there is room to run the wiring in the eave of the porch and into the support column, then out a small hole to the floodlight. I do not think I could phyisically put a receptacle box in the column for the wires though. Can any one tell me where in the NEC I am required to have a receptacle box for this situation? Also, do I need to run outdoor rated wire when running wires in the eaves? Thanks for the help.
chronojosh is online now   Reply With Quote
Old 03-12-2011, 05:51 PM   #2
Master Electrician
Rewards Points: 3,920
Are the wires in the eaves exposed or shelterd from the weather? Use a round or rectangular weatherpoof box fastened to the post with the wire entering through the back of the box.
brric is online now   Reply With Quote
Old 03-12-2011, 05:56 PM   #3
Rewards Points: 165
The wires in the eaves will not be exposed to the weather.
Old 03-13-2011, 09:33 AM   #4
Just call me Andrew
Rewards Points: 1,020
You can put a box like this, might help. Very shalow mounting bracket with a built-in box.
http://www.arlcatalog.com/Siding/Sid...t-in%20Box.htm
Andrew
secutanudu is offline   Reply With Quote
Old 03-13-2011, 10:53 AM   #5
I assume the requirements for a box in this situation is simply found in the requirement that all connections be accomplished inside a box. Besides being code, this sounds like a good, and safe, idea to me. Since you will have connections between the supply and fixture wires, this tends to point to a need for a box.
oberkc is offline   Reply With Quote
