Outdoor Flood Lights- Completely Disconnected? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-16-2012, 08:58 AM   #1
Outdoor flood lights- completely disconnected?
Hello,
I am hoping someone can give me some home electric advice with a wiring issue I am having.
I recently bought a home, and I have two floodlights outside which do not work. I do not have much experience working with electic, but I figured I would be able to at least diagnose why there is no power going to these lights.
After taking off the fixture and seeing with a multimeter that no power at all was coming through the wires, I went up into the attic to look at the actual wiring. I discovered three wires that had been shoved into a small cutout in one of the rafters, the cutout being about the size of a quarter in diameter. I pulled the wires out and they were not connected to anything, as if they had been cut, or previously joined together in some way. I traced the wires back to their origin: one going to each of the flood light fixtures, and one going to the circuit breaker box. I then went into my garage and discovered that the other end of the wire going to the circuit breaker box was not connected.
I have a few questions:
Does anyone have an idea of why these wires may be in their current state instead of being connected?
Is this something that I could fix myself easily, or am I in over my head with having limited experience working on electric.
Any help is greatly appreciated.
Thanks,
Will
mrhat557 is offline   Reply With Quote
Old 01-16-2012, 09:05 AM   #2
Julius793's Avatar
It's possible there was a short somewhere in the line so they disconnected everything, what should be done is run every thing new however if you dont have experience with electric I don't suggest you do it.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Problem: Puck lights w/ touch-sensitive switch mapsedge Electrical 1 03-14-2011 08:20 AM
Low Voltage Exterior Stair Lights Jupe Blue Electrical 2 02-16-2011 07:28 AM
New lights in basement CooperChloe Electrical 11 01-11-2009 12:22 PM
Adding can lights to an existing circuit TexasEd Electrical 1 06-17-2008 08:23 PM
Added can lights, tripping GFI tandyt Electrical 3 05-18-2008 10:55 AM
