Outdoor Fan, Switch And Receptacles - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-04-2013, 06:33 PM   #16
Rewards Points: 214
Originally Posted by Philly Master View Post
FYI there are 2 kinds of outdoor fans .. DAMP location and WET location use one of those 2
I already have that issue covered. Thanks.
rosem637 is offline   Reply With Quote
Old 06-05-2013, 05:33 AM   #17
Rewards Points: 214
One more quick question. I know I will need a "wet" location rated fan but what time of box will I need to support this from being that we will use PVC conduit?
Old 06-05-2013, 11:58 AM   #18
JW
mm11's Avatar
Rewards Points: 596
FYI- you can use a damp location rated fan also.
Hang the fan from a fan-rated box. Since the underside of the porch roof will be, at most, a damp location, it's permissible to use boxes listed for dry locations. Make sure to use long lag screws to support the box to a structural member.
mm11 is offline   Reply With Quote
Old 06-05-2013, 02:17 PM   #19
Resi EC
Rewards Points: 252
Hang the fan from a fan-rated box. Since the underside of the porch roof will be, at LEAST, a damp location, it's NOT permissible to use boxes listed for dry locations. Make sure to use long lag screws to support the box to a structural member.
Fixed it for ya!
Gac66610 is offline   Reply With Quote
Old 06-05-2013, 06:31 PM   #20
JW
mm11's Avatar
Rewards Points: 596
Originally Posted by Gac66610 View Post
Fixed it for ya!
How do you figure that?
Underside of roof- definitely not a wet location. Could be a damp location, as specified in NEC, or possibly dry.
Boxes are only required to be listed for wet locations, not damp. Using a box for dry locations is fine as long as it's installed so moisture cannot enter or accumulate.
The Following User Says Thank You to mm11 For This Useful Post:
rosem637 (06-05-2013)
Old 06-05-2013, 08:47 PM   #21
Resi EC
Rewards Points: 252
deleted
Old 06-05-2013, 09:08 PM   #22
Resi EC
Rewards Points: 252
Chapter 1
Definitions
Location, Damp. Locations protected from weather and
not subject to saturation with water or other liquids but
subject to moderate degrees of moisture. Examples of such
locations include partially protected locations under canopies,
marquees, roofed opened porches, and like locations,
and interior locations subject to moderate degrees of moisture,
such as some basements, some barns, and some cold-
storage warehouses.
Old 06-09-2013, 08:08 AM   #23
Rewards Points: 214
ANy thoughts on if this arrangement would function or would it cause the GFI to trip? The duplex, which is shown at ceiling level, will have both halves switch controlled.
Old 06-09-2013, 08:30 AM   #24
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
Good to go.
Coastal South Carolina
Old 06-09-2013, 08:42 AM   #25
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Originally Posted by rjniles View Post
Good to go.
Possibly...if this is being installed in a basement or garage the receptacle the shop light is plugged into would need GFI protection according to the 2008 NEC or later.
Dimmer Switch wired to receptacles? TrailerParadise Electrical 20 02-02-2013 11:21 PM
replacing old receptacles with new decora on a 3 way light switch furniture man Electrical 3 03-06-2011 09:23 AM
Light Switch kicks receptacles... SUfan7581 Electrical 6 04-04-2009 09:16 PM
installing new switch & 2 receptacles Rixbak Electrical 3 10-12-2008 03:49 PM
1 switch split receptacles Price pfister Electrical 16 05-03-2007 10:01 PM
