Outdoor Fan, Switch And Receptacles - Electrical - DIY Chatroom Home Improvement Forum
Old 06-03-2013, 07:24 AM   #1
Rewards Points: 214
Outdoor fan, switch and receptacles
Have a roof covering my patio and now want to install a couple receptacles, a switch and a ceiling fan under the roof. Power from the panel will go first into a GFI outlet. Then I want to add another outlet that will be powered from the LOAD side of the GFI. I am a little confused on how to take power to the switch.
In the diagrams below is one way more preferred over the other as far as the load side of the GFI giving power to the other receptacle and switch(1) or should the power for the switch be grabbed with the line side of the GFI(2)?
All wires will be run in PVC conduit underground and along wood framing of support for roof.
Outdoor fan, switch and receptacles-new-bitmap-image.jpg   Outdoor fan, switch and receptacles-new-bitmap-image2.jpg
rosem637 is offline   Reply With Quote
Old 06-03-2013, 07:31 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,172
Either diagram is fine. Use 2 if keeping the fan (and possible light kit) running if the GFCI trips is important to you. Personally I would use 1.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 06-03-2013, 07:55 AM   #3
Rewards Points: 214
Because in 1 the switch and fan are protected by the GFI?
Old 06-03-2013, 01:23 PM   #4
A "Handy Husband"
rjniles's Avatar
Not necessary
Old 06-03-2013, 01:52 PM   #5
jproffer's Avatar
Rewards Points: 706
I would also go with #1, for the reason you stated, maybe...but more-so because I could use 12-2 instead of 12-3. And I'm a cheap azz
jproffer is offline   Reply With Quote
Old 06-03-2013, 02:47 PM   #6
Rewards Points: 2,516
The poster said they are running PVC conduit so individual conductors I assume will be used.
hammerlane is offline   Reply With Quote
Old 06-03-2013, 05:28 PM   #7
jproffer's Avatar
Rewards Points: 706
Oops...well you're right
Doesn't change things though. There's no need to have separate circuits.
Old 06-03-2013, 07:59 PM   #8
Resi EC
Rewards Points: 252
Go with drawing (1). if you do drawing (2) it will trip when you use the fan.
Use single conductors,(THWN), romex is not permitted in wet locations
Gac66610 is offline   Reply With Quote
Old 06-03-2013, 08:08 PM   #9
Rewards Points: 214
Thanks to all who gave advice. I thought just the opposite that it would could trip if I went with #1. Why could it trip with drawing #2?
On another forum someone said:
"The fan should be high enough that it would not need to be on the GFCI, so either wiring diagram will work. I, personally, do not like to see stationary motors wired through a GFCI because of false tripping, so I would use the second one"
Old 06-03-2013, 08:28 PM   #10
Resi EC
Rewards Points: 252
In (2) you're pulling the neutral from the LOAD side of the GFCI, and the feed from the LINE side, the GFCI will see that whats going out on the LOAD black(feed) does not equal the LOAD white(neutral) coming back, causing the GFCI to trip
The Following User Says Thank You to Gac66610 For This Useful Post:
rjniles (06-03-2013)
Old 06-03-2013, 08:35 PM   #11
A "Handy Husband"
rjniles's Avatar
Good pickup.
The Following User Says Thank You to rjniles For This Useful Post:
Gac66610 (06-03-2013)
Old 06-03-2013, 08:43 PM   #12
Resi EC
Rewards Points: 252
surprised you missed it, you have given a lot of good advice around here
Old 06-03-2013, 08:49 PM   #13
A "Handy Husband"
rjniles's Avatar
What can I say, senior moment.
Old 06-04-2013, 04:22 AM   #14
Rewards Points: 214
That kind of makes sense. I may setup a circuit on my bench using just a light bulb in place of the fan and test this out.
Old 06-04-2013, 04:49 AM   #15
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
FYI there are 2 kinds of outdoor fans .. DAMP location and WET location use one of those 2
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Dimmer Switch wired to receptacles? TrailerParadise Electrical 20 02-02-2013 10:21 PM
replacing old receptacles with new decora on a 3 way light switch furniture man Electrical 3 03-06-2011 08:23 AM
Light Switch kicks receptacles... SUfan7581 Electrical 6 04-04-2009 08:16 PM
installing new switch & 2 receptacles Rixbak Electrical 3 10-12-2008 02:49 PM
1 switch split receptacles Price pfister Electrical 16 05-03-2007 09:01 PM
