Old 12-10-2012, 06:35 PM   #1
Outdoor cord was wet and plugged in
I was plugging in Christmas lights into outlet outside, I think the prong was wet, I saw a flash and now the outlet is dead. Circuit breaker didn't move. Could we have a fire in the wall?
rpiscitel is offline   Reply With Quote
Old 12-10-2012, 06:43 PM   #2
Licensed electrician
You might want to check for a tripped GFI.
Old 12-10-2012, 06:56 PM   #3
Super Moderator
Most out door outlets are protected but a ground fault circuit interrupter--(GFI)
Look at the outlet--see if it has a push button to reset it--
If not--check the breaker box for a breaker with a reset button and the usual switch.
If not---look around the house for a gfci outlet that is tripped.
Old 12-11-2012, 05:33 AM   #4
Did you learn a lesson from this experience ?
This is why GFCI's are handy to have.
We all let our guard down sometimes.
NUFF SAID.
dmxtothemax is offline   Reply With Quote
Old 12-11-2012, 07:32 AM   #5
Most likely a tripped GFCI somewhere as was mentioned. You owe your guardian angel one "attaboy"
I am sure you would know that by now.
danpik is offline   Reply With Quote
