Outdoor Conduit & Leakage - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-20-2013, 02:58 PM   #16
Rewards Points: 150
Alright I think I'm in good shape. Got the compression fittings to cap off the EMT and connect to a rigid / threaded LB connector. 6" rigid for the vertical, and then threaded hub with a gasket to fit the box. I don't see water getting in there anywhere.
Do you want pipe tape on outdoor threaded joints? i.e. will it block the electrical connection there?
-mike
SquishyBall is offline   Reply With Quote
Old 03-20-2013, 06:20 PM   #17
Oso954's Avatar
Rewards Points: 784
What compression fittings did you get ?
The Halex at HD are indoor compression fittings.
Rain tight fittings are rated "wet location".
They look similar, but are different.
Oso954 is online now   Reply With Quote
Old 03-20-2013, 07:32 PM   #18
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
I love watching these simple projects turn into difficult ones....
Old 03-20-2013, 08:26 PM   #19
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Wanna buy a low volt ring?
Old 03-20-2013, 08:27 PM   #20
E2 Electrician
Ha!
Old 03-21-2013, 09:27 AM   #21
Rewards Points: 150
http://www.homedepot.com/p/Halex-1-2...1631/100129507
Old 03-21-2013, 09:55 AM   #22
Rewards Points: 150
Well... I wouldn't say it reached "difficult" stage -- I just wanted it done right. Whoever did it the first time indeed had indoor fittings.
Another outdoor conduit (takes a low voltage line from my water meter to the outside sensor) I redid... was so full of water the entire inside was filled with rust. It is awful that A) conduit is required here for every little thing even low-voltage wires, and B) ppl install it but then put in wrong fittings which negates all the benefit of having conduit, and C) whoever installed the AC must not have had it permitted cuz I can't imagine an inspector would pass an indoor 90 in a wet location.
I'm pretty confident what I have now will work, so I appreciate the advice!
Old 03-21-2013, 12:55 PM   #23
jproffer's Avatar
Rewards Points: 706
If it was buried, it wouldn't have mattered what kind of fittings or conduit was used...it would have been full of water eventually.
jproffer is offline   Reply With Quote
RO filter plumbing Loop below sink - Water Leakage pxr Plumbing 6 02-19-2013 04:01 PM
Water Leakage Under Basement Window Well Slomarmoreno Plumbing 2 09-18-2012 06:40 PM
Main ABS Drain Pipe Leakage Unclev Plumbing 8 03-03-2012 07:03 PM
How to test pond pump motor for current leakage? Timster Appliances 12 11-25-2008 04:26 PM
Baseboard Air Leakage atw58 Building & Construction 2 03-03-2008 09:01 PM
