Outdoor Christmas Lights Fuse Keeps Blowing - Electrical - DIY Chatroom Home Improvement Forum
Old 11-18-2011, 09:59 AM   #1
Rewards Points: 207
On Tuesday we put up our Christmas lights on our house, they are the big C9 lights. We outline our garage and then take them up and across the gutters across the house. This is the 3rd year we've used them. We've never had any problems before this year. But for some reason the fuse in the first strand keeps blowing We have replaced it 2 times already since we put them up. They will run for awhile, but then after a few hours, it always blows. We aren't sure what's going on or what we need to do to fix the problem. We have checked the wires and all of the bulbs.. everything looks good. Not sure what else to do?? We can't really separate the strands.. because we don't have enough plug ins outside.. and because of the outlet location.
Any help would be greatly appreciated!!
mhp8982 is offline   Reply With Quote
Old 11-18-2011, 10:11 AM   #2
Rewards Points: 1,418
Are these lights daisy chained, end to end? This can overload the first string in the chain if you have too many strings in a row.
Perhaps when you replaced a few bulbs every now and then, the replacements drew a watt or two more than their predecessors, and the individual watts add up.
Old 11-18-2011, 10:14 AM   #3
Rewards Points: 207
I believe there are 4 strands connected together. But like I said, we only have one outlet, so I'm not sure what else we could do. Plus the location of the outlet makes it hard to break it up anyway. And they have worked fine like this the past 2 years.
Old 11-18-2011, 11:01 AM   #4
Rewards Points: 1,528
Get lower wattage lights like leds. You'll never blow a fuse again.
bob22 is offline   Reply With Quote
Old 11-18-2011, 11:19 AM   #5
Rewards Points: 207
We may have to do that for next year.. but I'd like to keep using these this year, since it's hard to get them up. Guess we may just have to keep changing fuses.
Old 11-18-2011, 07:24 PM   #6
dmxtothemax's Avatar
Rewards Points: 5,098
Put an amp meter on the circuit and monitor the currant,
It is probably too close to the maximum capacity of that line,
That would explain why it is blowing at odd times.
I would either isolate that string,
or put in lower wattage lamps,
Do it this year ! dont leave it till next year.
Or you risk a fire or electrocution.
dont risk it !
dmxtothemax is offline   Reply With Quote
Old 11-18-2011, 11:10 PM   #7
Rewards Points: 506
Send a message via AIM to theatretch85
Just run an extension cord along with the first string and plug the second string into the cord. I've done this in the past when I had a similar issue, if you have green cord lights, find a green outdoor extension cord approx the same length as your first light set (or even the first and second string).
theatretch85 is offline   Reply With Quote
big fuse problem randallatha Electrical 6 01-02-2011 12:07 PM
Landscape lights BlueBSH Landscaping & Lawn Care 2 02-24-2010 10:43 PM
New bulbs, good fuse, still no lights...HELP! TJMS81 Electrical 10 02-26-2009 10:52 AM
New lights in basement CooperChloe Electrical 11 01-11-2009 12:22 PM
Fuse Boxes For Showers Petrena Electrical 3 09-13-2008 02:36 AM
