Outdoor A/C Compressor Cut-off Safety - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-08-2012, 08:17 AM   #16
Electrical Contractor
jbfan's Avatar
Rewards Points: 648
My take on this is, the black, red and green wire come from a premade whip that is feeding the AC unit.
The incoming power is connected to the bottom of the disconnect.
This is way past time for diy help, and needs to be professionally repaired before some poor AC tech gets his di** knocked into the dirt!
The Following User Says Thank You to jbfan For This Useful Post:
stickboy1375 (08-08-2012)
Old 08-08-2012, 06:20 PM   #17
JB, that's what it's looking like to me.
After researching it a bit more, I believe the main breaker is three-phase, strangely (it's residential, but this house was built 50-60 years ago). It used to have some brand of main breaker that was known for causing fires, so that was replaced 10-20 years ago with a new main panel. The main 200A breaker is a powerpact qdl32200, not a qdl22200, which I think indicates 3-phase. http://i.imgur.com/xJeCV.jpg
This one a/c compressor at issue is the only three-phase appliance in the house, but I think it's a legit 3-phase circuit and the compressor says 3-phase on the label.
For the image above, the two sides (black) are 120v, and the middle (red) is 208v (sum of two 1/3 out of phase feeds), measured vs ground. ALL differentials (right to middle, right to left, middle to left) are 240v. (These are valid numbers, it's a true rms multimeter). That seems like it could work, but I don't understand why the middle conductor feeding into the main breaker from the top (the red one) is smaller.
Furthermore, the three wires (my previous post, picture) coming out of the three-slot breaker, the top and bottom (black, red) are 120v, the middle (white) is 208v. So that must be getting converted to 3 120v wires somewhere between the breaker box and the cut-off switch, I guess.
What I don't get is why the feed whip from the A/C unit doesn't have a ground to be tied into the ground from the house breaker box. However, since it must have come with the compressor which was made in 2004, I'm going to assume the people involved knew what they were doing even though I don't understand it.
mike31 is offline   Reply With Quote
Old 08-08-2012, 06:23 PM   #18
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
You have a high leg delta service... I never understood why these were installed at a residential property...
Phase to phase you get 240 volts, phase to neutral you will get 120v except on phase "B" this is the bastard leg, or high leg... NEVER, EVER use this leg for Line to Neutral loads....
Looking at the Main breaker picture indicates a "open-delta high leg" meaning you have two transformers, instead of three for a true "open delta"
The Following User Says Thank You to stickboy1375 For This Useful Post:
mpoulton (08-09-2012)
Old 08-08-2012, 06:27 PM   #19
E2 Electrician
Someone hacked the installation, I dont know why, but its hacked. And you really need to call a licensed electrician to come and repair all the insane violations.
Old 08-09-2012, 03:22 AM   #20
Semi-Pro Electro-Geek
Rewards Points: 2,990
This is a three phase circuit. The white wire on the breaker is the third phase, and is improperly colored. That yellow tape on that wire in the panel should be orange, and indicates that it is the "high leg" of the service (208V to ground). The worst part (hopefully) is that they switched to green for the third phase in the disconnect! That's awful. Hopefully that green conductor isn't connected to the chassis of the condensing unit...
mpoulton is offline   Reply With Quote
Trap and washing machine safety drain pan wildbilly Plumbing 18 03-05-2013 07:08 PM
Are these good respirators and safety masks? darsunt Tools 3 02-24-2013 07:34 PM
Homeowners And Safety. Roofmaster417 Roofing/Siding 0 05-03-2011 11:41 PM
Safety Arms for Bilco-style basement exterior doors? mark2741 Building & Construction 1 04-07-2010 07:46 PM
Construction safety nightmare 'Andyman Off Topic 2 09-13-2005 11:20 AM
