Outdoor 50A Receptacle - Electrical - DIY Chatroom Home Improvement Forum
Old 01-21-2012, 08:22 PM   #1
Question
outdoor 50A receptacle
my boss wants me to install a 50A recept on the outside corner of a house in order to operate a welder. the welder will be plugged in when used & then unplugged when not in use. since this is an outdoor application, it must be GFI protected, but a regular indoor GFI seems superfluous in this case, not to mention the wire size im running is too large to land on the GFI terminals. i believe i need a GFI breaker for the panel, is that correct?
hantz101 is offline   Reply With Quote
Old 01-21-2012, 08:27 PM   #2
MarginallyQualified
Rewards Points: 2,464
Get a good Receptacle:
http://www.wylaco.com/CEP-SR50-Recep...therproof,-50A
NEMA Rating 3R Weatherproof - NEMA Receptacle (1) CS6369 CEP SR50
and then a 2p 50A GFI Breaker
This is a Cutler Hammer:
Old 01-21-2012, 08:31 PM   #3
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Did you already tell your boss you knew how to do this?
titanoman is offline   Reply With Quote
Old 01-21-2012, 08:31 PM   #4
Rewards Points: 6,652
Suggest the boss hire a licensed electrician. Just tell him that you are unable to do it. If you want to educate yourself on the codes regarding, you can get a copy of the NEC, or look through it at NFPA.org for free. 50 amp gfci breakers are expensive. Here is some listings at nextag.com http://www.nextag.com/50-amp-breaker-gfci/stores-html
Old 01-21-2012, 08:39 PM   #5
Licensed electrician
Rewards Points: 1,028
A regular GFI receptacle would only be rated up to 20 amps.
You should follow the advice and tell your boss to hire someone.
Old 01-21-2012, 08:59 PM   #6
Master Electrician
Rewards Points: 3,678
Why do you believe this circuit should be GFCI protected?
brric is online now   Reply With Quote
Old 01-21-2012, 09:01 PM   #7
Hello, it's outside.
The Following 3 Users Say Thank You to Jim Port For This Useful Post:
gregzoll (01-21-2012), mpoulton (01-21-2012), Speedy Petey (01-21-2012)
Old 01-21-2012, 09:05 PM   #8
" Euro " electrician
frenchelectrican's Avatar
Well., I can see where this is going and I will suggest that you get a electrician do this due you are working for your boss at the customer house there is few issue will arise.
Why not just rent a gaz powered welder/generator unit if you do need to use the welder for short time.
Merci,
Marc
Old 01-21-2012, 09:06 PM   #9
Master Electrician
It's not a 125 volt 15 or 20 amp circuit. Code reference please/
Old 01-21-2012, 09:06 PM   #10
Yeah .,, C'est outside I will thow the snowball all the way across the pond and get ya.
Merci,
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
Old 01-21-2012, 09:20 PM   #11
Electrical Contractor
jbfan's Avatar
Rewards Points: 142
I would think he is kidding!!!!!!!!!
At least I hope so!
The Following User Says Thank You to jbfan For This Useful Post:
Old 01-21-2012, 09:25 PM   #12
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
Tell your boss to stop being cheapskate and hire someone qualified to do this.
Old 01-21-2012, 09:26 PM   #13
Missouri Bound's Avatar
I did not think that a 50A 240v circuit meets the conditions which require a GFCI....am I wrong? My references are for 120v 15 or 20 amp circuits only in specific wet areas and / or outdoors. Have I missed something?
Old 01-21-2012, 09:29 PM   #14
Only for a spa Missouri Bound. Welder, just a normal circuit. I would think that the welder would trip the gfci anyways, due to the nature of the beast.
Old 01-21-2012, 09:35 PM   #15
You missed the tone of my voice. Yes I was kidding.
Replacing receptacle with GFCI wiring problem braden Electrical 8 04-06-2011 09:32 AM
low voltage reading at receptacle 2 ball cane Electrical 5 04-06-2011 01:07 AM
Receptacle under mirror quincy Electrical 5 03-24-2011 02:40 PM
Wiring a receptacle for a lift station hydrogeo99 Electrical 4 08-18-2010 02:04 AM
Receptacle Rating question Ultrarunner2017 Electrical 19 12-20-2008 07:20 PM
