Out Side 200 Amp Meter Box With Breaker Slots - Electrical - DIY Chatroom Home Improvement Forum
Old 10-06-2010, 10:57 PM   #1
Out Side 200 amp Meter Box with Breaker Slots
This is a old house that has a 100 amp breaker panel for front section of the house and 60 feet away has another 100 amp breaker panel. It would be very difficult to install a 200 amp breaker panel and do away with the second one . Someone jumped from the first panel to the second one using just 60 amp breakers for each panel.I found that there is enough 100 amp wire to run to the each 100 amp breaker panel to the 200 Amp Service panel on the house with the power Meter. that has breaker slots.
Question, would it be ok to put a 2 100 amp breakers here to power each panel I would like to know in detail the best way to do this, the house has been this way for 25 years with no electrical problems. Please contact me at billylothride@yahoo.com
BillyL60 is offline   Reply With Quote
Old 10-06-2010, 11:12 PM   #2
You talking to me?
nap's Avatar
Rewards Points: 6,290
what is "100 amp wire". I understand what you are referring to but what is the actual size of the wire?
It sounds like running from the 200 amp meter main is a possibility.
HA! Breaker setup, also a few questions. CoconutPete Electrical 6 05-05-2010 12:26 PM
Main 50 amp breaker in meter room keeps tripping Dennis Diaz Electrical 7 04-21-2010 07:42 AM
Proper grounding of meter main to breaker panel tns1 Electrical 3 09-08-2009 09:24 AM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 05:55 AM
100amps meter with 200amp breaker box? Snooker Electrical 3 04-15-2007 01:39 PM
