Out Of Ideas - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-27-2012, 09:56 PM   #16
Rewards Points: 164
Exterior of the house??? I saw one once where the GFCI was the outside outlet, yet it turned off the bathroom.
ryan50hrl is offline   Reply With Quote
Old 08-27-2012, 10:11 PM   #17
JOATMON
ddawg16's Avatar
Rewards Points: 1,968
My in-laws outlet in the garage was powered by the GFIC in the upstairs bathroom at the back of the house....go figure....
I'm going to assume that more than one outlet is without power....I would start checking all outlets to see which one(s) don't have power....you are just going to have to start pulling things apart to find it....
I bet tomorrow you figure out which outlets are controlled by which breakers.....
One of the first thing I did when I moved into my house was to map out every single outlet and light.
Old 08-27-2012, 10:50 PM   #18
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
receptacle and light...
Old 08-27-2012, 10:57 PM   #19
JOATMON
ddawg16's Avatar
Outlet....receptacle....electrical distribution socket.....what ever it takes....
(one of these days I'll get it right)
The Following User Says Thank You to ddawg16 For This Useful Post:
stickboy1375 (08-27-2012)
Old 08-27-2012, 11:05 PM   #20
E2 Electrician
LOL... i was just teasing.
Old 08-28-2012, 04:21 AM   #21
raylo32's Avatar
Rewards Points: 1,292
These days with copper and labor through the roof and $15 GFCIs, I guess the math has changed.
GFCI's were expensive, labor and wire was cheap. economics baby...
Live long and prosper.
raylo32 is offline   Reply With Quote
Old 08-28-2012, 06:26 PM   #22
Quick update, I had an electrician come take a look at it and he determined that one of the neutral lines was broken (probably burned). At this point I wish it was a tripped GFCI. Anyway, now he wants to run a new line to the receptacle, but determined that he could tie the neutral to the ground temporarily to give me lights in my bathroom. Yay. Thanks for all the advice though!
tomanon68 is offline   Reply With Quote
Old 08-28-2012, 06:42 PM   #23
kevinp22's Avatar
Rewards Points: 252
had a bad feeling the problem wasnt a tripped gfci
Make sure that temporary solution doesnt become permanent
My house was full of temporary splices and hack "plug extensions" when i moved in
EDit: I would NEVER do this in my house.
kevinp22 is offline   Reply With Quote
Old 08-28-2012, 07:15 PM   #24
Electrical Contractor
jbfan's Avatar
Rewards Points: 552
If that was his advice, I would fire him in a heartbeat.
No self respecting electrician would even suggest that.
If it is an open neutral, it can only be wherever there is a connection, so at the panel, or first receptacle or whatever else is on this circuit.
The Following 3 Users Say Thank You to jbfan For This Useful Post:
Jim Port (08-29-2012), Missouri Bound (08-28-2012), stickboy1375 (08-29-2012)
Old 08-28-2012, 07:56 PM   #25
Missouri Bound's Avatar
You are kidding, right? Any REAL electrician would not advise anyone to do this.
Do you want it your way or the right way?
The Following 4 Users Say Thank You to Missouri Bound For This Useful Post:
jbfan (08-28-2012), Jim Port (08-29-2012), kevinp22 (08-28-2012), stickboy1375 (08-29-2012)
Old 08-28-2012, 08:40 PM   #26
JOATMON
ddawg16's Avatar
Come on guys....hold the testosterone.....
It could be either one.....no different than a mechanic making a quick diagnoses on a car....he might be right....he might be wrong.....I look at it as 'shotgunning'...
With that said....
The 'likelyhood' of a neutral wire opening at a location other than a receptical...is remote....not impossible...but unlikely....
While I may not have the experience with residential electrical stuff like some of you guys...I deal with electrical in a commercial basis daily.......I have NEVER seen a neutral open up anywhere other than at a connection.
As I said before....the OP needs to map out all his breakers....then start at the first connection for the affected ckt and start working his way to the bad connection. This is just basic grunt work......
Old 08-29-2012, 06:23 AM   #27
jbfan's Avatar
Rewards Points: 552
Dawgs, read the part where the "electrician" wants to tie onto the ground wire to complete the circuit!
Old 08-29-2012, 06:49 AM   #28
Licensed electrician
Rewards Points: 1,778
Tying the neutral to a ground creates a shock hazard on all the metal parts of the system. Anyone that would suggest something so dangerous needs some serious re-training and/or a head slap. No knowledgeable electrician should have suggested this even temporary fix.
The problem will be at the last working or first non-working device. It is just an easter egg hunt to find it.
Old 08-29-2012, 07:55 AM   #29
Master Electrician
Why the sudden influx of supposed electricians suggesting to tie the neutral and the ground together?
There can't be that many idiots out there can there?
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 08-29-2012, 08:17 AM   #30
Rewards Points: 3,256
Originally Posted by Jim Port View Post
and/or a head slap.
zappa is offline   Reply With Quote
Tags
breaker doesn't trip , no gfi , reset doesn't work
Loft bedroom ideas! Help! Alexz7272 Interior Decorating 5 12-31-2011 09:10 PM
Redecorating DD's room....thoughts, ideas? Looong. RealHouswifOfOK Interior Decorating 14 04-22-2011 06:19 PM
Loo9king forward to ideas nanalane9 Introductions 3 03-25-2011 08:07 AM
Garage shelving ideas koodawg General DIY Discussions 3 12-31-2010 09:52 AM
Ideas needed for kitchen reno (pic included) bearcats23 General DIY Discussions 5 05-24-2010 08:36 PM
