Out Of Ideas - Electrical - DIY Chatroom Home Improvement Forum
Old 08-27-2012, 07:30 PM   #1
Out of Ideas
I plugged in the vacuum to the bathroom outlet, turned it on and it went off immediately -- also the lights and outlet stopped working. I unplugged the vacuum, located my breaker box and the breaker was not tripped. I switched it off and back on anyway and still nothing. The breakers are labeled quite well, but just to be sure, I turned each one on and off, including the main breaker...still nothing. The bathrooms don't have GFI (I know I should get them) and there are no GFI plugs in the house. Furthermore, I used a voltmeter to measure the voltage just beyond the breaker and I'm getting 120V. However, at the outlet, nothing. Any more suggestions would be appreciated. Thanks in advance!
Background: I'm an electrical engineer, so feel free not to baby me.
Possible next steps: Switch the outlet and see if that is the problem? I fear that I may need an electrician to come out and replace the line...ugh.
tomanon68 is offline   Reply With Quote
Old 08-27-2012, 07:36 PM   #2
Rewards Points: 13,446
An electrical engineer and no GFI's in the bathroom or kitchen Hmm.
Might want to start by removing the outlet and see if it's back stabed and check the incoming power from the wires not the outlet.
Old 08-27-2012, 07:38 PM   #3
I just moved into this house about 2 weeks ago. GFIs are on my to-do list. As far as the voltage at the outlet, I checked the wires. I should have clarified that in the initial message.
Old 08-27-2012, 07:41 PM   #4
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Hidden gfi that tripped.
The Following User Says Thank You to stickboy1375 For This Useful Post:
Missouri Bound (08-28-2012)
Old 08-27-2012, 07:44 PM   #5
kevinp22's Avatar
I had this happen to me.
The vacuum "surge" was just enough to push a loose connection to the point of no return.
If there is voltage from hot to ground, check neutral connections especially
Otherwise, check both hot and neutral
Check the last working "thing" on the circuit or the first non working "thing"
"thing" = receptacle, light, switch, you get the ideas
Install a GFCI in the batroom ASAP. Dont put the light on the load side of the GFCI
kevinp22 is offline   Reply With Quote
Old 08-27-2012, 07:54 PM   #6
I'm not getting voltage across anything at the first "thing", which would be the outlet in the bathroom. I think I have to call an electrician...
Old 08-27-2012, 07:57 PM   #7
Electrical Contractor
kbsparky's Avatar
Originally Posted by tomanon68 View Post
... there are no GFI plugs in the house....
Look again. Some of the older houses had ONE GFI outlet, which could be located in a garage, outside, or in some other obscure place.
It would feed all the other GFI required outlets downstream.
Betcha you tripped it!
Here is one thing you can test for to see if you actually have a tripped GFI or not:
Test for continuity between the neutral and ground at the dead outlet.
IF you don't have continuity, you most likely have a tripped GFI, as those disconnect both the hot and neutral conductors....
-KB
Old 08-27-2012, 08:06 PM   #8
kevinp22's Avatar
you are sure the power doesnt come into the light fixture first, with an always hot to the receptacle and a switch loop to the wall switch. or power first to the light switch and then branch out from there
do what KB sparky told you to do first, but as a last resort open up the switch and light boxes.
then call the pro
Old 08-27-2012, 08:13 PM   #9
raylo32's Avatar
Rewards Points: 1,252
Good possibility. My house is set up with a GFCI in the garage that feeds all the bathrooms and outside outlets. First time it popped it took me a good while to figure it out.
Live long and prosper.
raylo32 is offline   Reply With Quote
Old 08-27-2012, 08:26 PM   #10
E2 Electrician
My house is the same way as well, one 20amp GFCI breaker that does the whole house requirement, man I would love to wire in those days.
Old 08-27-2012, 08:32 PM   #11
Upon further investigation, I discovered several GFCI -- in the garage, by the washer/dryer, pool, etc. I pushed reset on each and every one of them and nothing. I also seem to have misplaced my voltmeter, which means I can't check to see if the GFCI is even the problem. Great. Guess I'm calling in a pro. Thank you to everyone that offered guidance.
Old 08-27-2012, 08:44 PM   #12
kbsparky's Avatar
Betcha the garage one is the culprit. I'd start with that one.
-KB
Old 08-27-2012, 09:03 PM   #13
raylo32's Avatar
My house really isn't that old (1995) and there are 2 separate GFCI circuits/outlets in the kitchen with the GFCIs actually right there in the kitchen. It's just that one in the garage that seems wierd and it feeds the 2 full bathrooms upstairs and half bath on the middle level plus the front and back outdoor receptacles. I don't know why they went through all that wiring rigamarole to save a couple of local bathroom GFCIs?
Also for the OP... GFCIs can fail. One of my kitchen GFCIs died and I had to replace it.
Old 08-27-2012, 09:25 PM   #14
E2 Electrician
GFCI's were expensive, labor and wire was cheap. economics baby...
Old 08-27-2012, 09:41 PM   #15
Just a quick update: I'm still searching around my house for hidden GFCIs. No good news as of yet.
Tags
breaker doesn't trip , no gfi , reset doesn't work
Loft bedroom ideas! Help! Alexz7272 Interior Decorating 5 12-31-2011 09:10 PM
Redecorating DD's room....thoughts, ideas? Looong. RealHouswifOfOK Interior Decorating 14 04-22-2011 06:19 PM
Loo9king forward to ideas nanalane9 Introductions 3 03-25-2011 08:07 AM
Garage shelving ideas koodawg General DIY Discussions 3 12-31-2010 09:52 AM
Ideas needed for kitchen reno (pic included) bearcats23 General DIY Discussions 5 05-24-2010 08:36 PM
