Our Lights Are Intermittently Flickering - Electrical - DIY Chatroom Home Improvement Forum
Old 09-06-2012, 07:55 PM   #1
Our lights are intermittently flickering
Just started a few days ago. It's all the lights in the house at once. They flicker fairly dramatically for a 2-3 second period. Seems to be random intervals between episodes. What could be causing this? How dangerous is it?
tomsmyth is offline   Reply With Quote
Old 09-06-2012, 07:58 PM   #2
Rewards Points: 13,712
Are the lights on differant circuts, or all on the same breaker?
Old 09-06-2012, 08:43 PM   #3
You may have a loose neutral somewhere
SpragueElectric is offline   Reply With Quote
Old 09-06-2012, 08:45 PM   #4
Different breakers.
Old 09-06-2012, 08:47 PM   #5
Could this perhaps be due to rats? We've had rats in the attic. Still working on getting them out.
If it's a loose neutral, how long might it take an electrician to diagnose and fix it? How much might it cost?
Old 09-06-2012, 08:51 PM   #6
kevinp22's Avatar
Dont give rats a bad rap
Probably not due to branch circuit wiring if its all the lights in the house. your utility neutral may have a problem (is it worse when its windy?) this is a very bad situation that can fry your sensistive electronics
call the Power Company ASAP and have them check the outside. If all okay on their end, bring in an electrician to check your panel/service entrance wires
No one can estimate cost. Depends on too many variables. If its a POCO problem it should be free.
kevinp22 is offline   Reply With Quote
The Following User Says Thank You to kevinp22 For This Useful Post:
oh'mike (09-06-2012)
Old 09-06-2012, 08:52 PM   #7
could be a number of possibilities and how long it may take can vary depending on how quick the problem can be found, so its hard to put a time on it.
Old 09-06-2012, 08:53 PM   #8
If there on differant circuts I'd be calling the power company to check the power from the pole to the meter base.
If it is there nutural that bad it can wipe out anything that's pluged in at the time. And has been known to cause a fire.
It's not likly rats just happen to eat two differant wires that happen to both control the lights.
Old 09-06-2012, 09:06 PM   #9
DIY staff
Rewards Points: 7,174
-) this is a very bad situation that can fry your sensistive electronics
I second this one---the most likely suspect is out side of your house---
In the mean time unplug anything with a computer chip--microwave--furnace--t.v. ---if it's a neutral problem you could get a power surge on some circuits.
Old 09-06-2012, 09:08 PM   #10
Just called Georgia Power. I hope it's their problem!
Old 09-06-2012, 09:12 PM   #11
good luck hope the best for you, Neutral problems are never good
The Following User Says Thank You to SpragueElectric For This Useful Post:
kevinp22 (09-06-2012)
Old 09-07-2012, 09:32 AM   #12
POCO said voltage was fine on their side but he 'repinched' the connection at the pole anyway. So far there hasn't been any flickering since he did that. Hopefully it stays that way....
Old 09-07-2012, 10:24 AM   #13
kevinp22's Avatar
thanks for the follow up
Wouldnt expect voltage to be wierd except when its flickering. Tightening the connection hopefully solved your problem.
If it happens again, time to call the pro
flickering lights rcdltd Electrical 2 12-19-2011 11:39 AM
Need info on replacing 8 recessed lights in bathroom OhmZoned Electrical 1 11-07-2011 12:35 PM
lights flickering when compressor running awdblazer Electrical 1 10-30-2011 08:09 AM
New lights in basement CooperChloe Electrical 11 01-11-2009 11:22 AM
undercabinet puck lights ccalmonte Electrical 7 08-05-2008 08:25 PM
