Old 02-11-2009, 02:16 PM   #1
OTR Microwave - no power
I am wanting to put in a new OTR microwave.. There was no hood or power in the cabinet above before now. Will I need an electrician to run power to the cabinet above where I want the microwave? Or can I run something myself.. House is all electric..
rocketgirlcolor is offline   Reply With Quote
Old 02-11-2009, 02:38 PM   #2
If you are asking that means you should hire an electrician.
Old 02-11-2009, 07:56 PM   #3
Licensed electrician
Your microhood will require a dedicated circuit run all the way back to your panel.
If your house is finished it may pay you to hire someone that know how to get wires installed behind drywall with minimal damage.
Old 02-12-2009, 06:55 AM   #4
Pe Plan your ventilation requirements as well
Chemist1961 is offline   Reply With Quote
Old 02-12-2009, 02:33 PM   #5
DIY'er
jamiedolan's Avatar
Code referance please.
Jamie
Jamie Dolan - Neenah, WI
Need Help Uploading Photos?
jamiedolan is offline   Reply With Quote
Old 02-12-2009, 07:54 PM   #6
It's there.....somewhere.
220/221 is offline   Reply With Quote
Old 02-12-2009, 08:23 PM   #7
Electrician
By adding a microwave to a kitchen it is considered an appliance covered by the 20amp counter top appliance circuit. this circuit can be tapped and a receptical can be placed in the cabinet to power the microwave. ducting the exaust is another story, some units have the option to vent it outside with a duct or redirecting in to the kitchen in the event there isn't a duct. code on the branch circuit can be found in NEC Artical 210.
spark-451 is offline   Reply With Quote
Old 02-12-2009, 08:43 PM   #8
If it's sitting on the counter. This one's mounted above the range. Dedicated circuit.
Old 02-12-2009, 09:13 PM   #9
Licensed Pro
Jamie
An OTR microwave is also a range hood that is connected by a cord and plug. 2005 NEC Article 422.16 (B)(4) says that such a range hood must have an accessible receptacle supplied by an individual branch circuit.
Instructions included with the OTR units also specify a dedicated circuit.
OTR Microwave no power rocketgirlcolor Appliances 2 02-19-2009 07:25 AM
Wring for Lincoln Power Mig Welder vstoyko Electrical 17 01-15-2009 07:15 PM
safe way to add extension to power cord sil Electrical 7 10-18-2007 10:58 PM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 02:55 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 11:23 PM
