OT: How Do High Voltage Lines Work? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-13-2009, 07:56 AM   #16
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 138
Originally Posted by CDH View Post
I think you are referring to a tri-plex house service which does have the bare wire neutral,the insulation is really pretty durable and if shaped properly will pose no problem to soffits etc,the one thing that you have to watch for is squirrels love to knaw the insulation off of the hotlegs, kind of ironic is'nt it Red Squirrel LOL.
Haha yeah. The reason squirrels and other rodents do this is to wear out their non stop growing teeth.
unfortunatly, not all rubber snakes have a juicy center!
Red Squirrel is online now   Reply With Quote
Old 08-14-2009, 08:59 AM   #17
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
Originally Posted by J. V. View Post
Jamie. Next time, count the insulating spacers between the pole and the line. I read somewhere (I think it was a quote from Tom Henry) that each individual insulator was rated at 10,000 volts. So 10 insulators would be 100,000 volts. Now, thats some serious voltage.
Hello;
Sorry for the delayed response, I've been out of the road much of this week. I did look at some poles next to 41 in Oshkosh, and they looked like they were 6 or 7 insulators. I think the large towers I saw by I-43 in south Milwaukee were even larger, with more insulators, I'll have to check those out next time I'm down there.
Jamie
Jamie Dolan - Neenah, WI
Jamie Dolan Paw Dogs
Need Help Uploading Photos? Click here.
jamiedolan is offline   Reply With Quote
Old 08-14-2009, 09:01 AM   #18
DIY'er
jamiedolan's Avatar
Originally Posted by Gigs View Post
Went to the Hoover Dam while I was in Vegas... talk about a lot of HV... It's like entire fields full of towers:
The towers up on the hill in your photo look very similar to the ones I saw off of I-43 in South Milwaukee,WI.
Jamie
Old 08-14-2009, 09:11 AM   #19
DIY'er
jamiedolan's Avatar
Originally Posted by frenchelectrican View Post
James.,
We have bunch of 245KV lines near Appleton area and yes there is a 500 KV transmmison line run near here.
And Not too far from my home/ shop have few 134KV line as well that is transmmison and hevey local spur to one industrail customer { a chesse factory in Hollandtown }
The Forest Junction Sub station it was expanded about 2 or 3 years ago they allready more than double up the sizewise IMO almost triple of it and we have one 245 KV line came from Pullman plant { Green Bay steam turbine base load plant } that allready have larger conductor on it.
But we have few 134KV transmmison spurs to couple towns as well.
Merci,Marc
Hello Marc;
Again, I apologize for the delayed response. It's great to hear from you, as I find it very interesting to hear about whats in our area.
Is most of the Fox Cities area fed from the Pullman plant in Green Bay? I know Menahsa has run a separate power plant for years, but I have not heard of very many small towns that do.
Jamie
Old 08-14-2009, 05:20 PM   #20
Wire Chewer
Rewards Points: 138
Out of curiosity how much amps would be running on a typical transmission line. As voltage goes up, amps go down, but I'm sure it's still a rather large number considering the load on there is cities worth of usage!
Old 08-14-2009, 05:41 PM   #21
Semi-Pro Electro-Geek
Rewards Points: 2,990
Typically at least a thousand, up to a few thousand per consductor. Bundled parallel conductors allow more per circuit. The limit is usually thermal - the conductors heat up and sag too much, and the aluminum outer layer separates from the steel inner layer due to differential thermal expansion.
mpoulton is offline   Reply With Quote
Old 08-14-2009, 08:23 PM   #22
" Euro " electrician
frenchelectrican's Avatar
Originally Posted by jamiedolan View Post
Hello Marc;
Jamie
Yes part of the WPS Pullman plant do feed part of Appleton and Part of Oshkosh as you see they allready upgrade the transmmison line on the state road 41.
I know Menasha do have it own powerplants IIRC steam turbine gas fired unit plus they should have a peaking plant a new one few years but the deal fell thru and keep diesel unit for peaking units { there is 4 peakers thru out the city of Menasha and 3 in Appleton plus one hydrodam unit}
But there are some specfic time of day they will " import " aka buy power from other POCO's grid system when the rates are cheaper especally at nite time it more common they do that
The typical amparange useally on the transmission line will varies a bit but anywhere from 100 to 3000 amps depending on the conductor and voltage class it is on it.
Merci,Marc
Old 08-15-2009, 08:51 PM   #23
Wire Chewer
Rewards Points: 138
Wow that's a lot of amps, being a lineman must be a shocking experience. :p No mistakes allowed on that job for sure.
Speaking of mistakes, imagine what would happen if these guys decided to exchange tools or something.
Old 08-16-2009, 07:48 AM   #24
Rewards Points: 1,548
Usually when a power company with its own generators needs to import power from "the grid" this is
needed during peak hours.
Many older colleges generated some power from a steam plant that provided the heat for the buildings. At mine,
when I was there, the power load was such that the only time the generators provided the entire load was on
winter nights (maximum steam usage and minimum power load). At that time their AC frequency control was
not accurate and when the college system went off the grid, all synchronous clocks were off by several minutes
come dawn. Various methods were experimented including having someone manually adjust the frequency all
night long to compensate. Nowadays the ratio of generated power to campus demand is such that
considerable power needs to be purchased all the time.
water lines on slab toolbelt Tina Plumbing 6 05-21-2009 07:05 PM
how many trunk line and feeder lines Grandma Lewis HVAC 4 03-08-2009 06:07 PM
Will water lines freeze if placed behind insulated stud wall in basement? jpsmith Remodeling 22 03-05-2009 12:23 PM
Where are the "Carpenters" ???? wrldruler Carpentry 14 09-11-2008 07:37 AM
2 - 900w tansformers on a 15A circuit? tonyBagadonuts Electrical 19 07-20-2008 07:15 PM
