Organizing Kitchen Circuitry - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-12-2008, 08:13 AM   #16
When is fishing season?
CowboyAndy's Avatar
Originally Posted by pcampbell View Post
5) Kitchen outlets have to be GFCI. Either 15 or 20. I don't see any reason to run this as a 15 amp unless your wiring dictates that. You need to have at least 2 separate small appliance branch circuits, even if you only have 2 outlets. In short, off the top of my head, every piece of counter space needs to be within 24" of an outlet, but you can stop when you go around the sink.
SABC must be 20 AMP.
I DON'T OWN MY HOUSE...
MY HOUSE OWNS ME!
CowboyAndy is offline   Reply With Quote
Old 06-12-2008, 04:17 PM   #17
Electrician
I've never seen 15 amp GFIs but apparently they exist.
Here ya go... personally I dont see why you would want a 20 amp GFI, The only thing in a residence i've seen that actually had a 20 amp cord on it was a treadmill... pretty tuff spot in the kitchen for it...
chris75 is offline   Reply With Quote
Old 06-12-2008, 05:38 PM   #18
joed's Avatar
Rewards Points: 12,370
Well if you live in Canada then a 20 amp circuit MUST use 20 amp T slot receptacles. It is a code requirement.
Old 06-12-2008, 09:24 PM   #19
Electrician
Okay, but how many appliances are actually 20 amp? just curious.
Old 06-13-2008, 06:20 AM   #20
CowboyAndy's Avatar
I would guess not many. I have never actually used one.
MY HOUSE OWNS ME!
Old 06-13-2008, 06:40 AM   #21
Rewards Points: 270
I think it would have to be a combination of like a toaster and coffee maker going at the same time ?
Our coffee maker is 1100, toaster is 1800 but thats for 4 slices. In our kitchen, these are on different circuits.
Is the perpendicular line in the 20 amp receptacle simply an identifier, or are there actually plugs that have a prong like that?
pcampbell is offline   Reply With Quote
Old 06-13-2008, 07:49 AM   #22
CowboyAndy's Avatar
There are actually plugs that have the t blades on them, that would denote a true 20 amp appliance.
MY HOUSE OWNS ME!
Old 06-13-2008, 08:07 AM   #23
joed's Avatar
None really. But if it is a 20 amp breaker in Canada you must have the ability to plug in a 20 amp device. The T slot allows both 15 and 20 amp plugs to be inserted.
Old 06-13-2008, 08:25 PM   #24
Electrician
I realize that... but why enforce it?
Old 10-25-2008, 09:22 AM   #25
I have no definite idea why it is enforced. A neighbor of mine (in Ontario, Canada) recently had a rejection because a kitchen circuit looked as follows:
20 amp single pole breaker
20 amp yellow cable
20 amp T slot GFI receptacle
20 amp yellow cable
15 amp duplex receptacle
The inspector said that the second GFI had to be a 20 amp T slot. The only technical reason I can see for this is that you can plug two 10 amp loads into the 15 amp receptacle and this exceeds the rating for the device. The residential 15 amp and 20 amp receptacles appear to be identical in terms of the attachment screws, internal bus bars and break-off tab, although the stab connectors are obviously different. I suspect the difference is solely that they have not been UL tested/rated as a product.
Anyway, that's all irrelevant - it's code.
Paulustrious is offline   Reply With Quote
Old 10-25-2008, 08:04 PM   #26
joed's Avatar
Ontario code requires the receptacles to match the breaker. Therefore you are not permitted to put 15 amp receptacles on 20 amp circuits. It could have a 20amp T slot. It did not need to be a second GFCI. The first GFCI could have protected it if it needed protection because it was within 1m of the sink.
Old 10-26-2008, 04:50 PM   #27
Sorry - that was a typo. I meant to say second receptacle, not second GFI. It's odd how I can re-re-read something I wrote and not notice the mistake. Then again, I don't have to. Someone else will always point it out for me...
my kitchen reno - complete remodel (with concrete countertop) Knucklez Project Showcase 311 07-07-2014 05:07 PM
New floor/subfloor in kitchen. Need ideas DanBress Flooring 3 10-20-2008 08:31 PM
sagging kitchen off back of house DanBress Building & Construction 12 03-03-2008 09:20 PM
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 03:21 PM
Kitchen Cabinets and Walls ththomps Remodeling 4 09-18-2006 10:23 PM
