Options For Powering DC Xenon Lamphouse... - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-16-2013, 09:26 PM   #16
Common Sense Common Guy
Rewards Points: 161
Originally Posted by mpoulton View Post
Please post your results! I'm very interested in how this works out.
Well, after purchasing one of those very welders, I hooked it up and it works... sort-of. The bulb strikes and maintains an arc, although it is flickering a bit. The lamp house's ammeter shows only 10A, no matter what the pot setting on the welder. The setting on the welder doesn't seem to affect the arc at all.
My clamp ammeter is on the fritz, so I need to obtain a new one before I can see whether the lamp house's meter is good or not. That would also allow me to test dead-short current on the welder, to see if it truly passes the right amount of current or not.
Any other suggestions?
EDIT: Photo of the arc image in the viewing window:
flasherz is offline   Reply With Quote
The Following User Says Thank You to flasherz For This Useful Post:
mpoulton (05-17-2013)
Old 05-16-2013, 11:38 PM   #17
Rewards Points: 161
One more update tonight... I got it working at a full brightness, it seems that the welder did not like being attached to a short 14 AWG extension cord. I swapped it out for a 12 AWG cord and I was able to adjust the output to 45A. The lamp arc still flared/flickered more than I would like, but I'll see what it looks like when I get it reconnected to the projector.
Old 05-17-2013, 12:07 AM   #18
Idiot Emeritus
Rewards Points: 1,492
Capacitors across the DC lines might help with the flickering, but a choke would work even better.
micromind is offline   Reply With Quote
Old 05-17-2013, 12:41 AM   #19
Rewards Points: 161
Any thoughts on the right inductance / resistance for this application?
Old 05-17-2013, 01:18 AM   #20
Semi-Pro Electro-Geek
Rewards Points: 2,864
Cool! Glad to hear it mostly works. If you are observing visible flicker, it's probably the result of control loop instability rather than actual ripple on the power supply. The ripple should be 120Hz, which is invisible, as well as tens of kHz, which is even more invisible. The control loop instability may be the result of the arc characteristics not exactly matching the designers' expectations for a welding arc. The operating voltage is probably significantly higher than most welding arcs, which are usually in the 10-20V range IIRC. Although the welder should be capable of operating at rated current in the 20-30V range, it is not really designed for it. The ideal solution would be to do a little reverse engineering on the welder and change the loop control parameters. That probably comes down to a few resistors and capacitors, some of which may already be variable. This would require quite a bit of hacking to figure out though. Adding a large choke in series with the lamp may help solve the problem by smoothing out the nonlinearity of the lamp's high frequency I-V response. As much inductance as you can muster would probably work well. Hundreds of millihenries should be the right ballpark. #8 wire wrapped on a core from a microwave oven transformer would probably be a good bet. I would NOT use a pi filter without knowing the loop control parameters of the power supply, since the frequency response of the pi filter can further destabilize the power supply under some circumstances.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is online now   Reply With Quote
The Following User Says Thank You to mpoulton For This Useful Post:
flasherz (05-17-2013)
Old 05-17-2013, 02:17 AM   #21
I couldn't help doing some hacking. I took apart my welder. It's based on a UC3846 SMPS controller, the middle 16-pin IC at the top edge of the back of the main board. All the passive components that set its operating parameters are right near it. It is switching at 74kHz, which is higher than I expected for a power supply this big. It is a current-mode controller, operating in a symmetrical drive topology (probably push-pull; I didn't look at that part) using deadtime to control the power output. It has pulse by pulse current limiting as well as some kind of foldback protection which essentially kills the output if the load impedance drops below a certain limit. The open circuit voltage is much higher than the manufacturer says! It's 70-80V RMS, over 100V peak. There is a small ferrite output inductor, but that's all. It does not significantly smooth the 74KHz output ripple, and is probably only there to filter RF noise. There is a lot of filter capacitance on the input, and the 120Hz ripple seemed minimal but I was testing at relatively low power.
I'd try a huge inductor in series with the lamp first. I suspect that will improve the situation a lot. If it does not work, you may need to consider messing with the passive components controlling the frequency response of the error amp and current sense amp in the UC3846, and whatever they've done with the pin 1 current limit control, which is probably responsible for the foldback behavior and might be messing with your lamp operation.
Old 05-17-2013, 03:05 AM   #22
And another thing: This SMPS topology is subject to "subharmonic oscillation", which is a form of chaotic instability at any duty cycle above 50%. It can be compensated for, but it's hard to do and the compensation depends on the load characteristics. You'll know you have subharmonic oscillation if the power supply makes a hissing noise, and the lamp may flicker randomly. I've run into this a few times on laser power supplies and have never been able to properly solve it when it happens. It's like electronic black magic, as far as I'm concerned. This welder might be designed to ignore the problem since it might not matter for welding. If your lamp demands greater than 50% duty cycle from the UC3846, that chaotic behavior may be causing your problem.
Old 05-17-2013, 11:22 AM   #23
Rewards Points: 161
I'm having a hard time in various searches to find a large enough choke with enough inductance - have any supplier suggestions, or am I going to end up rolling my own here? I can find plenty of 50A, but usually only in the range of 1-10 mH or less.
Old 05-17-2013, 12:46 PM   #24
You'll have to roll your own for something this large. The core from a microwave oven transformer is great for this. Just hacksaw the windings and pry them out with a screwdriver, then wind your own with #8 wire. Disassembling a cheap AC welder should yield something usable that's even bigger, and you could probably just re-use the original secondary winding as the inductor.
Old 05-17-2013, 07:59 PM   #25
Idiot Emeritus
If nothing else, use the choke from the original rectifier.
The Following User Says Thank You to micromind For This Useful Post:
Inexpensive Siding options that that aren't Vinyl or Metal GumbyMan Building & Construction 15 01-06-2013 12:01 PM
Recommendations for heating and cooling options for my home? daluu HVAC 2 12-23-2012 02:31 PM
Shower options Chilidog Tiling, ceramics, marble 3 06-06-2012 05:28 PM
Maytag dishwasher has 5 cycles and three options. only one cycle works and no options wwejj0926 Electrical 1 04-22-2012 06:54 PM
Replacing undercabinet halogen bulb with xenon bulb gabbie14 Electrical 10 09-26-2011 11:46 PM
