Old 08-10-2008, 11:48 AM   #1
Optional Method
How do you determine the calculated load of a 6 Kw electric space heater unit and a 4 kW A/C using the optional method?
I thought when it was reasonable to assume that both of these units would not operate at the same time, that the lower wattage unit could be disregarded in the calculation and that the larger wattage could be used.. But the answer seems to be 4000 watts. I do not understand how they arrived at that answer. This question is from a 2005 NEC quiz.
Thank you
Bernard1599 is offline   Reply With Quote
Old 08-10-2008, 12:25 PM   #2
J. V.'s Avatar
Optional Method
Post question at wwwmikeholtforums.com. All pros!
Grout application...Need an alternative method Termite Flooring 16 06-24-2008 06:39 PM
Best Method To Sleeve Slab Penetrations jrepp Building & Construction 4 12-28-2007 06:02 PM
Which bonding method proper??? Nestor Electrical 2 09-15-2006 07:18 AM
Over 8 Foot Wall - Method of Applying Sheathing... MoparAutoworks Building & Construction 14 08-20-2006 08:38 PM
Types of flex duct and support method wingam00 HVAC 1 06-04-2005 02:12 PM
