Option To Fitting All The Wire Connection On 5 Gauge Box - Electrical - DIY Chatroom Home Improvement Forum
Old 03-27-2013, 12:00 PM   #1
Option to fitting all the wire connection on 5 gauge box
I have a 5 gauge box and I would like to know what are the option to tackle this without having all those wire fit inside or outside? How can I do this withing the code?
amb1s1 is offline   Reply With Quote
Old 03-27-2013, 12:27 PM   #2
Rewards Points: 512
You're gonna have to try this again. I don't know what a 5 gauge box is, nor what your question is.
Old 03-27-2013, 12:50 PM   #3
Sorry, I meant 5 gang box. I'm going to have 5 switch on this box and I think there is going to be too many cables inside it. So I think what is the best way to handle this issue.
Old 03-27-2013, 01:04 PM   #4
Rewards Points: 512
What is the size of the box?
Is it plastic, or steel?
Will you have all single pole switches, or some 3-ways, dimmers, etc.?
14 AWG or 12 AWG cable?
Old 03-27-2013, 03:27 PM   #5
One trick is to just run the wires for the switches to that box. Make your other connections in a junction box or elsewhere. Like a junction box in the attic or use several junction boxes in the attic.
And use a deeper box and/or a box extension to make it deeper.
Also if you use a 5 gang plaster ring, there will be additional space as that connects to a larger box.
Be sure to use a level when installing the box. Any "tilt" will show with multiple gang boxes.
P.S. You need to go to an electrician's supply to find/order this stuff...
Billy_Bob is offline   Reply With Quote
Old 03-27-2013, 03:28 PM   #6
I'm using 14 AWG, I'm using dimmer and switches. Here is the model that I'm using:
http://www.amazon.com/Smarthome-2477...insteon+switch
Here is the box that I'm using:
http://www.homedepot.com/p/t/2033434...1#.UVNVwqWuiMU
Old 03-27-2013, 03:35 PM   #7
I like the idea of the junction box. So I would have the wire from the breaker end on the Junction Box and then have the 5 cables from the 5 switches connect to the main cable on the Junction Box. Then, I have just 5 wire entring the 5 gang box.
Old 03-27-2013, 03:58 PM   #8
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
You will have no problem concerning wire fill assuming:
power in
power out
5 switch legs
You will have room to spare.
Old 03-27-2013, 06:23 PM   #9
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,214
I do not like the idea of junction boxes. No reason to add more possible trouble points to a circuit. Wired properly you should have no trouble wiring 5 switches/dimmers in a 5 gang box.
Coastal South Carolina
The Following 4 Users Say Thank You to rjniles For This Useful Post:
Billy_Bob (03-27-2013), frenchelectrican (03-27-2013), Jim Port (03-27-2013), Speedy Petey (03-27-2013)
Old 03-27-2013, 06:39 PM   #10
Right. Also junction boxes have an advantage that there are no switches or outlets which need to be "stuffed" in there. So plenty of room.
Light fixtures also have this advantage. They usually sit flush with the box and do not take up room inside the box. So you could also make connections at a light fixture instead of the switch box.
And you don't need one junction box for everything. You can use several if you wish. Just so they are accessible like in an attic.
These can come in handy later for troubleshooting or adding additional things to a circuit.
I've never had trouble with any electrical connections in a junction box because I twist the wires first (using electrician's pliers), then firmly twist on the wire nuts. Nothing comes loose.
Old 03-27-2013, 06:50 PM   #11
A "Handy Husband"
rjniles's Avatar
A properly sized switch or receptacle box, does not require wire be stuffed into the box. Folded back in the correct manner, they will fit fine.
Who wants to be crawling around in a hot attic looking for a junction box.
The use of a bunch of unnecessary junction boxes is amateurish.
Billy_Bob (03-27-2013), brric (03-27-2013), Jim Port (03-27-2013), Speedy Petey (03-27-2013)
Old 03-27-2013, 07:24 PM   #12
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
I would have split them up. I DO NOT like anything bigger than a 4-gang box. Once you get over 4-gang plates get really difficult to find.
The Following User Says Thank You to Speedy Petey For This Useful Post:
Old 03-27-2013, 07:46 PM   #13
Licensed electrician
Rewards Points: 1,616
If the box is plastic it will have the maximum number of conductors allowed in it on the back. If metal the code will have a chart for fill.
Old 03-27-2013, 11:05 PM   #14
" Euro " electrician
frenchelectrican's Avatar
For the readers you may noticed why Speedy Petey mention that due anytime you pass more than 4 gang switch boxes the issue is the switch plate cover it will get more harder to find and the cost as well so normally I useally split it it look better and easier to deal with it.
Merci,
Marc
3 wire to 4 wire generator connection possible? jws3 Electrical 30 11-28-2012 07:39 PM
Wire Gauge and Circuit Breakers Red Truck Electrical 21 01-21-2012 06:33 AM
10 Gauge wire with 30amp circuit and Baseboard Heat? RocketManZ Electrical 4 12-17-2011 12:19 PM
What gauge wire for 100 ft run? philesq Electrical 6 07-19-2011 10:50 PM
What size ground wire should I use for 8 gauge power dxmullin Electrical 1 07-06-2011 02:57 PM
