"Opposing" Duplex Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 01-31-2013, 10:20 AM   #1
I am looking for an "opposing" 20 amp duplex outlet (if there is such a thing) or something similar. By opposing I mean where one receptacle has the ground on the top and the other receptacle has the ground on the bottom (I have never seen one but wonder if they exist). I have two 90 degree plugs that need to be plugged into on outlet. I have seen outlets that swivel so that the 90 degree plugs don not hit each other but I have only been able to find 15 amp ones. I appreciate any suggestions or info.
Rick5472 is offline   Reply With Quote
Old 01-31-2013, 11:12 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 552
Why does it have to be a 20 amp receptacle?
Old 01-31-2013, 11:22 AM   #3
Maybe something like this:
http://www.smarthome-products.com/p-...alabaster.aspx
sixspeed is offline   Reply With Quote
The Following User Says Thank You to sixspeed For This Useful Post:
Rick5472 (01-31-2013)
Old 01-31-2013, 11:30 AM   #4
I was thinking something like this...
Old 01-31-2013, 11:43 AM   #5
It's a refrigerator circuit.
Old 01-31-2013, 12:43 PM   #6
Rewards Points: 109
It really depends on what else is plugging into that receptical. If it's a low amp draw like a single light then 15A would be ok although I believe not code (refrigerator should be on a dedicated circuit if the plate says so though but IMO that's more of a suggestion). Just because it's on a 20A circuit, the 15A receptical is fine for a fridge. The problem would be if your other plug was for a high draw appliance like a microwave or something.
What's on plug #2 ??
Daltex is offline   Reply With Quote
Old 01-31-2013, 01:44 PM   #7
Yes...it is a microwave.
Old 01-31-2013, 01:58 PM   #8
Rewards Points: 109
I'd run a seperate circuit then. That really is asking for trouble running both on the same circuit.
I'm over my head on this one so wait for an electrician to give you advice. I think the issue is whether the microwave is a fixed install or counter top. You need to have the max amp draw of both also. If the microwave is running and the frigerator cut's on the defrost cycle it could be over the circuit limit and trip the breaker.
I'm sure someone will be along that can help you more.
Old 01-31-2013, 02:01 PM   #9
MCB
sparky
Uh oh, two dedicated circuits on one component that may or may not exist... Better to do it right instead of a problematic fire starter.
Run two circuits for both those appliances.
MCB is offline   Reply With Quote
Removing lightswitch control half of outlet duplex nelluk Electrical 21 02-23-2017 03:11 PM
small secondary countertop outlet issue rasz Electrical 8 11-07-2011 04:14 PM
Odd voltages at outlet TJF Electrical 12 11-01-2011 09:13 PM
Outlet before light switch; Open Neutral? Fox Electrical 21 09-26-2010 08:38 PM
GFCI duplex outlet that can be fed with two circuits? timothyt Electrical 3 05-28-2010 10:21 PM
