Opinions On Tandem Breakers - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-08-2013, 10:04 AM   #16
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Originally Posted by busman View Post
1. There is a white wire attached to the ground bar.
Yes I have to mark that end green or replace it it's for my tankless water heater
2. The 8 black/red conductors aren't marked with the type. If they are part of a cable assembly, where are the EGCs?
Yes just some scrap wire I had around that I used for my tankless water heater used a white wire for a ground.
3. The 200A CB is marked as Service Disconnect, but it is served by a 4-wire cable.
Came with that sticker did not know it was a code violation. Panel is a sub main is 100' away in the garage.
4. There appear to be circuit breakers that are not Siemens in the panel.
All murray breakers in a murray/siemens panel
5. Depending on the wire size, the 8 red/black cables may be overfused and/or exceed the conduit fill limits.
#6 on a 40 amp breaker total 9 #6 wires in 1-1/4" conduit not over fused or over conduit fill. Actual draw on wires is about 30 amps each.
Mark
I just used the scrap wire for the tankless water heater till I got something else but I just left it there for now. It's on my list along with straightening out the panel.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 02-08-2013, 10:23 AM   #17
Rewards Points: 720
Thanks for the feedback. I wouldn't stay up nights worrying about the scrap wire if it's only going a few to the water heater. I would definitely color that white wire green ASAP, although that is also technically a violation since it is smaller than #4.
Mark
busman is offline   Reply With Quote
Old 02-08-2013, 10:56 AM   #18
rrolleston's Avatar
Mark
Thanks for the info.
GE Panel - Breakers - Tandem or Slim? TBrown1 Electrical 12 06-05-2012 08:42 PM
My 125A Square D HomeLine will not accept tandem breakers brons2 Electrical 3 11-01-2010 12:49 PM
SQUARE D TANDEM 15A SP Breakers 57_Hemi Electrical 6 07-31-2010 12:02 AM
Can I install tandem breakers to stop my breakers from tripping? sofakng Electrical 1 04-29-2009 02:44 PM
Sub-Panel or Tandem Circuit Breakers? dgoldsmith Electrical 2 03-08-2008 01:34 PM
