#1 |
Electrical Enthusiast
Opinions on Tandem Breakers
I was wondering if anyone has opinions on tandem breakers..
I know the issue of shared neutrals comes up, but apart from that are they just as safe as regular/full sized breakers? Are there circuits that they shouldn't be used on? I've used a couple where needed, and have also seen an all-tandem 100 amp service (Surprise, it was in a mobile home )
#2 |
Licensed Electrician
As long as the panel is rated to take tandem breakers
Not a fan of the new layout.
Answers based on the National Electric Code. Always check local amendments. |
#3 |
Electrical Contractor
Personally, I don't like `em.
As for shared neutrals, most of the time, using a tandem on a multi-wire circuit is not proper installation protocol: Many times, I have encountered a tandem breaker feeding a multi-wire circuit, it was incorrectly installed resulting in an overloaded neutral.
-KB Life is uncertain -- eat dessert first!! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#4 |
I installed a 20 space 40 circuit panel and ended up using quite a few tandems. But only think I notice is that the panel seems a little cramped with wires because it's smaller.
Please ask me about my special discount for people that shut up and stay out of my way! With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe. |
#5 |
" Euro " electrician
I don't mind to use the tandem breakers only if they are listed in the panel and you have to becarefull with MWBC espcally this is true with GE breakers they are famous for this one if not carefull.
Single circuits that is not a issue. Merci, Marc
The answer will be based on NEC ( National Electrical code ) or CEC ( Cananda Electrical code ) or ECF ( Electrique Code France ) |
#6 |
Yeah I like that my panel does not take up as much room as a 40 space panel would have. It's a mess because it was a rush to get back in our home someday I would like to straighten out some of the wires but not too big of a deal right now.
#7 |
Electrician
I think tandems and quads have a higher failure rate than full size. Full size dissipates heat better. Pack in the tandems and the whole panel runs hotter. And do old work on a circuit, or replace a breaker, and many times you should be using an arc fault. I don't think they're ever going to make tandem arc faults.
#8 | |
Master Electrician
Opinions on Tandem BreakersQuote:
Mark
Licensed Master Electrician Commonwealth of Virginia |
#9 | |
Licensed Electrical Cont.
Sometimes I feel like if I answer any more questions it is like someone trying to climb over a fence to jump off a bridge and me giving them a boost. |
#10 |
...yet...
#11 |
| The Following 2 Users Say Thank You to Speedy Petey For This Useful Post: | jbfan (02-08-2013), rrolleston (02-08-2013) |
#12 |
Who knows what's coming in the future!
Yes I am a Pirate, 200 years too late. "Jimmy Buffett" |
#13 |
Please let me know so I can fix them? With code reverences so I can learn why in the code book.
Please ask me about my special discount for people that shut up and stay out of my way! With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe. Last edited by rrolleston; 02-08-2013 at 09:27 AM. |
#14 |
Master Electrician
1. There is a white wire attached to the ground bar.
2. The 8 black/red conductors aren't marked with the type. If they are part of a cable assembly, where are the EGCs? 3. The 200A CB is marked as Service Disconnect, but it is served by a 4-wire cable. 4. There appear to be circuit breakers that are not Siemens in the panel. 5. Depending on the wire size, the 8 red/black cables may be overfused and/or exceed the conduit fill limits. Mark
| The Following User Says Thank You to busman For This Useful Post: | rrolleston (02-08-2013) |
#15 |
I can imagine a tandem arc-fault breaker would be bigger than the AFCIs that are already almost too large to fit in the panel.....
| Display Modes | |
| GE Panel - Breakers - Tandem or Slim? | TBrown1 | Electrical | 12 | 06-05-2012 08:42 PM |
| My 125A Square D HomeLine will not accept tandem breakers | brons2 | Electrical | 3 | 11-01-2010 12:49 PM |
| SQUARE D TANDEM 15A SP Breakers | 57_Hemi | Electrical | 6 | 07-31-2010 12:02 AM |
| Can I install tandem breakers to stop my breakers from tripping? | sofakng | Electrical | 1 | 04-29-2009 02:44 PM |
| Sub-Panel or Tandem Circuit Breakers? | dgoldsmith | Electrical | 2 | 03-08-2008 01:34 PM |
