Opinions of Ideal push-in wire connectors
1 Attachment(s)
For the last 18 months or so I have used nothing but Ideal push-in connectors for wiring connections in J-boxes. They are much easier to install than wire nuts, and, IMO, better for a DIY project in that they are easy to inspect to make sure the wire is installed solidly. I have read up on them, and they use a different connection system than the infamous 'back-stabbed' receptacles. From what I have read, there have been no reports of problems with Ideal connectors. If there is such a report, please post a link because I couldn't find it.
Anyway, one concern that has been raised is that they 'may' not be up to high amp loads. This winter, I ran a 1500W space heater in the basement pretty much 12 hours a day. The circuit was one I ran and connected with Ideals. After the circuit had run for many hours, I opened the J-Box and put a ammeter clamp on the hot wire and got a reading of 14 amps on the circuit. The connectors were cool to the touch and looked exactly the same as the day I had put them in, six months before. As far as I can tell, these things work as advertised. I know they are rated and approved for connections and are routinely used in new construction residential projects. Please post your opinions on these connectors. Thanks. Here is a box in my basement with them used for the connections. I used connectors with extra slots so I could add a circuit later. |
For what it's worth, a Master Electrician I know feels the same way as you, and will used only wire nuts. |
1 Attachment(s)
For what it's worth, I also like the plastic push in cable clamps. They work great!:wink: |
Here's another pic of the Ideal 'In-Sure'
http://www.efc-solutions.com/pdf/wireconnectors.pdf They have been around a while, at least four years Might be a good idea to pick some up One area is where you come across a box where some handyman has cut the wires super short. The Ideal 'In-Sure' should make an easier, faster connection where you can visually verify the contact |
I had no trouble pulling out a push-in connection in my dad's panel that was made with one of those things. It was about as easy as pulling out a push-in connection on, say, a 48 cent P&S single-pole toggle. Just to be safe, I threw it away and replaced it with a wire nut. When I see push-in connections, I think "lazy electrician."
I'm not an electrician, but I am a perfectionist. It annoys me when I see some of the shortcuts some hired professionals make. |
I understand the opinion that they are somehow 'less than.' This opinion is widely shared with those in the profession. What I would like to find out is proof that they are. In my experience (admittedly limited) they have performed quite well, with zero problems of any kind that I have observed. For what it is worth, I work in Codes and Regulations (not in electrical) and we (Metro Louisville) have approved these for years with no documented failures in any circuit, ever. |
I suppose we'll see how they're still doing in another 20 years. Will they still be working as well as a 30 year old back-stabbed outlet or light switch? :wink: |
Ive been seeing these wire connectors more prevalant in Halo and other recessed can lights as well. We just cut them off and hard wire all our can lights.
First time I used them, I noticed that the wires would turn inside the connector as I pushed it into the box. Looking inside the connector, the wires are now leaning to the left or right, depending on the way the wire is being stressed from outside the connector. That's not a good feeling for me.
I use them for existing grounds that have been cut short, otherwise I use wirenuts. |
One of the reasons I put an ammeter on a connection that fed a space heater was I wanted to see if the connection was warm. It wasn't. There was no evidence of heat, arcing or anything abnormal. If used properly, in a J-box, with strain relief on the cable I have no reservations about using them. |
Remember, the ideal 65 twister was approved by the ul. Just because the ul says its ok, doesn't mean it is. I'm not trying to say these are not solid connections, but I love wire nuts and will stay with them.
i won't use 'backstabbed spring clip' outlets. found them loose too many times......
but i WILL use what i THOUGHT at first was 'spring clipped' until the wire fell back out and i realised that you had to screw the side screw tight to clamp the wire inside. twist/wirenut/tape still seems to me to be the most secure for JBs though. DM |
Who needs to tape their wirenuts?
| All times are GMT -4. The time now is 04:47 PM. |
