Opinions On How To Add Slots To Full Panel - Electrical - Page 6 - DIY Chatroom Home Improvement Forum
Old 06-11-2013, 10:05 PM   #76
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 3,784
Originally Posted by Techy View Post
If you thank too many people, you lose your thanks button for a while.
THANK You Techy.... Guess I got Mr Computer beat on that one.
EDIT: Afterthought.... I wonder why they do that... I often use the "thank you" button to say "I agree"... but I guess I use it wrong
MTN REMODEL LLC is offline   Reply With Quote
Old 06-11-2013, 10:19 PM   #77
Electrical Enthusiast
Rewards Points: 504
I do the same thing.
Kyle_in_rure is offline   Reply With Quote
Old 06-11-2013, 11:03 PM   #78
Thanks Kyle... I woulda hit the "thank you" button, but I didn't want to loose my "thank yous".... sounds like congress must be involved in this.....
Old 06-11-2013, 11:25 PM   #79
Rewards Points: 504
Oh lord we could really go off on a tangent then.
Old 06-11-2013, 11:44 PM   #80
YEP...
Back to the OP's (Adis) main though, does anyone understand why on this split buss panel, are the two left hand top breaker slots (feeding the furnace as Adis has told us) do not appear to be a breaker at all... they appear to be just a buss tap.
Would not this violate haveing a main shutoff/disconnect (all right, one of six handle throws to shut down everything after the meter)???
Peter
Old 06-11-2013, 11:54 PM   #81
Sparky
Rewards Points: 510
It is a breaker, just the older long style, takes 4 spaces.
Techy is offline   Reply With Quote
The Following 2 Users Say Thank You to Techy For This Useful Post:
adis (06-18-2013), Kyle_in_rure (06-11-2013)
Old 06-12-2013, 12:01 AM   #82
Wow... Sharp bubbi... never seen that! Is that pecular to the buss, or can you replace that with a normal double.
Techy...
Old 06-13-2013, 02:57 AM   #83
Originally Posted by MTN REMODEL LLC View Post
Tecy and Gac make good points....Check the panel specs
Peter
OK, so I checked the panel info:
1. Model: CH14D200; "Use Cutler Hammer Type CH, CH2100 or CH 2100H Safety Breakers in the Service Section;" "use as SERVICE EQUIPMENT...;" "install no more than 6 Main Disconnects;" "Use 70A Max. Breaker for Lighting Section Main Disconnect;" 120/240V 1Ph. 3W.; 200 Amps Max.
2. "Use 50A Max. Breakers for Loads Opposite to Neutral." (what does this mean?)
3. Neutral Instruction Sticker...
Anyway, if it is OK to swap out the old LF-450 4-slot 90a breaker with a 2-slot CH290, that would free up 2 slots off the service section in the main panel which I can use for the planned garage circuits. Is there any reason why i couldnt do this? Thanks - mark
adis is offline   Reply With Quote
Old 06-13-2013, 03:02 AM   #84
BTW, is there some significance to the "Thanks" button? Do they keep metrics and have some sort of merit-based award/recognition system in place? just asking because if so, i want to give credit where it is due. thx - mark
Old 06-13-2013, 04:54 AM   #85
An old Tradesmen
Rewards Points: 8,142
You can see how many times someone has been thanked by visiting their profile. No reward is given to a member by it though.
Old 06-13-2013, 07:20 AM   #86
Resi EC
Rewards Points: 252
Can you post a pic of the panel cover spec sheet, thanks
If at first you don't succeed .... do not work on live electrical
Gac66610 is offline   Reply With Quote
Old 06-15-2013, 01:47 AM   #87
Here are the specs that i can find:
Garage Sub Panel Questions mscanlon01 Electrical 3 07-20-2011 10:03 AM
Old House Rewire finnimus Electrical 15 05-13-2011 10:39 PM
Renovating basement, main too full: sub panel plan, OK? renoman Electrical 6 08-18-2010 10:32 PM
Main Service Panel Full bobo Electrical 5 09-24-2007 07:13 PM
100A Panel is full...I Need more circuits redly Electrical 2 06-20-2005 06:26 AM
