Opinions On How To Add Slots To Full Panel - Electrical - Page 5 - DIY Chatroom Home Improvement Forum
Old 05-15-2013, 11:32 AM   #61
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 5,336
Originally Posted by Philly Master View Post
still two poles or L1 and L2 or 2 120 volts 180 degrees out of phase ...
Philly....
Don't have it in front of me.... but as I recall.....
in a vertical row: 4 individual 1" (allright fullsize not twin/tandem or slims) 50A breakers in main section (top of panel)
in vertical order:
breaker 1 on L1
breaker 2 on L2 (handle tied to breaker1)
breaker 3 on L1
breaker 4 on L2 (handle tied to breaker 3)
When I had panel open.... I could swear I remember seeing a total of 4 very neat feeds to two lighting mains and in effect 4 busses total below.
The feeds were very neat and I don't remember if they were lugged onto their busses or factory clamped..... I do remember I wondered if they were field wired or factory done.
I did wonder about the advantage/logic involved. I think it was a 70's panel.
It was a while ago... but I think I'm remembering right. And I am almost certain it was a GE.
Best
Peter
MTN REMODEL LLC is offline   Reply With Quote
Old 05-19-2013, 06:09 PM   #62
I'm thinking of a possible alternative to adding a panel in the garage - I've already got one in the utility room. The 90a breaker at the top of my main panel feeds a 12 slot 125a CH subpanel that is located in my utility room. Currently there are only two circuits on this panel, both 240v supplying my furnace, a 60a and a 30a. The wire leading to the panel is: "KAISER ALUMINUM - A TYPE SE CABLE TYPE XHHW CDRS 2 AWG AL 3 CDRS 600 VOLTS UL" it is about 45 feet from the main panel. The idea being that a bunch of the 240v loads in the house (furnace, water heater, dryer, well pump) are right next to each other in the utility room and I supply them power from the sub panel - thus freeing up slots in the main panel (located in the garage) for circuits in the garage.
What ampacity is the above wire, and can I swap a larger (125a) breaker at the main panel to feed this subpanel without changing wire?
Is 125a (or 100a) enough to run any of the other 240 loads off the subpanel? (ask me for any specs that you need.)
furnace (BAYHTR14158RK): circuit 1 - (@240v) 9.6 kW, heater 40a, min branch circuit 55a, max overcurrent 60a
circuit 2 - (@240v) 5.76 kW, heater 24a, min branch circuit 30, max overcurrent 30a
water heater (RHEPRO66-2-A): (@240v) upper 4500W, lower 4500W, total 4500W, currently on 30a circuit
dryer - no idea (average) currently on 30a
well pump - currently on a 240v 15a circuit, that's all I know.
Again, the idea is to free up breaker slots in the garage for 240v 30a and 120v 30a circuits by only changing breakers and wiring up loads myself (staying within my ability.) thanks for any opinions/info. - mark
adis is offline   Reply With Quote
Old 05-19-2013, 06:20 PM   #63
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
90 amps ....
9600 watts
5760 watts
4500 watts
5000 watts ( dryer )
24,860 watts not counting the well pump
24,860/240 = 103.6 AMPS ....
so No you cannot add all those
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
The Following User Says Thank You to Philly Master For This Useful Post:
adis (06-18-2013)
Old 05-19-2013, 08:47 PM   #64
Thanks for the reply, Philly. Let me make sure I've got this right, with the way the subpanel is wired right now, it is not possible to increase the current potential to the subpanel (by adding a larger breaker at the main) and be safely within NEC specs?
How about this: if 90a is the most I can run to the sub panel, and using your quick formula, if I run the furnace and water heater from the sub panel that figures to 83a. Is this a safe load?
Old 05-19-2013, 09:01 PM   #65
Rewards Points: 516
i did not look up #2 alum ..... for amp rating ...
what about the loads already there ??
Old 05-19-2013, 09:04 PM   #66
Licensed electrician
Rewards Points: 1,006
The feeder to the subpanel would need to be upgraded before you could change the breaker size upward.
No. 2 AL SE is only rated for 90 amps max under the 75 degree column. It would be less under the 60 degree column that may apply depending on the code cycle.
The Following 2 Users Say Thank You to Jim Port For This Useful Post:
adis (06-18-2013), Philly Master (05-19-2013)
Old 05-20-2013, 08:58 PM   #67
Yeah, that's what I was afraid of. thanks for the replies, guys!
Old 06-11-2013, 06:34 PM   #68
Sorry to keep resurrecting this thread guys, but I'm not giving up on a DIY solution to wiring up my garage just yet. Can somebody describe to me what type of breaker it is that is occupying the top 4 slots on my main panel (see the pic in post #1)? It's a 90a dual (?) breaker that is feeding a subpanel that is powering my furnace. Why is it necessary that it take 4 slots? Does it have something to do with the fact that my main panel is a split-bus type? Must it bridge the busses? Is there any reason why I couldn't replace it with a CH 90a two pole (thus freeing up two slots)? Thanks for any information
Old 06-11-2013, 08:06 PM   #69
Sparky
Rewards Points: 510
Just an older style, you can replace with the newer single side CH290, you can only install a 2 pole breaker in the 2 positions made available
Please remember there is no way to disconnect the bussing behind any of the top 6 positions on both sides(2pole taking up 2 positions)
Techy is offline   Reply With Quote
The Following User Says Thank You to Techy For This Useful Post:
adis (06-18-2013)
Old 06-11-2013, 08:13 PM   #70
Resi EC
Rewards Points: 252
I don't think you can do that, the stabs have ampere rating, using too much on one is not good.
The panel door should show the ampere rating of the buss stabs
Gac66610 is offline   Reply With Quote
Old 06-11-2013, 09:24 PM   #71
Tecy and Gac make good points....Check the panel specs
Techy or anybody... Can anyone tell me why I don't have a "thank you button" or a "multi=quote button" on this computer/site.
TIA
Peter
Old 06-11-2013, 10:13 PM   #72
Electrical Enthusiast
Rewards Points: 504
TIA
Peter
That's odd. Is it the new Site format? I have it on the iPhone app.
Kyle_in_rure is offline   Reply With Quote
Old 06-11-2013, 10:31 PM   #73
An old Tradesmen
Rewards Points: 6,074
TIA
Peter
Should have them.
Old 06-11-2013, 10:37 PM   #74
Kyle and Beenthere.... Thank you.... I got logged off doing something else... and now both are back.... maybe something I did...
Anyway...Thanks
Peter
The Following User Says Thank You to MTN REMODEL LLC For This Useful Post:
Kyle_in_rure (06-11-2013)
Old 06-11-2013, 10:58 PM   #75
Sparky
Rewards Points: 510
If you thank too many people, you lose your thanks button for a while.
Garage Sub Panel Questions mscanlon01 Electrical 3 07-20-2011 11:03 AM
Old House Rewire finnimus Electrical 15 05-13-2011 11:39 PM
Renovating basement, main too full: sub panel plan, OK? renoman Electrical 6 08-18-2010 11:32 PM
Main Service Panel Full bobo Electrical 5 09-24-2007 08:13 PM
100A Panel is full...I Need more circuits redly Electrical 2 06-20-2005 07:26 AM
