Opinions On How To Add Slots To Full Panel - Electrical - Page 4 - DIY Chatroom Home Improvement Forum
Old 05-14-2013, 09:08 AM   #46
Electrical Enthusiast
Rewards Points: 504
I always thought it might be interesting to bring back some sort of "modified" split bus design, so all of your AFCI-required circuits could be protected by one AFCI breaker. The upside would be cost, the downside would be one fault could trip all of your lighting circuits.
Kyle_in_rure is offline   Reply With Quote
Old 05-14-2013, 09:41 AM   #47
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 3,388
Not a bad idea on the cost side... except I'm sure that breaker somehow would be mucho $.
My understanding of the primary imputus for AFCI's was to prevent fryed/worn light and appliance cords.... if so.... why don't we just have all our appliance/light cords in FMC Oh sh--, better not give the NEC any ideas.
Peter
MTN REMODEL LLC is online now   Reply With Quote
Old 05-14-2013, 09:49 AM   #48
Rewards Points: 504
Peter
I personally don't like AFCIs. But I know "code is code" and if they save lives it's worth it.
The Following User Says Thank You to Kyle_in_rure For This Useful Post:
MTN REMODEL LLC (05-14-2013)
Old 05-14-2013, 10:14 AM   #49
Special User
Rewards Points: 1,230
Yup. The British already had that solved around WWII though, they put a fuse sized to the appliance in every cord's plug. So they can plug a 1A appliance with a 1A fuse into a 30A (or whatever) receptacle -- when the cord gets pinched or frayed, the fuse blows instead of creating a 30A firestarter.
Christmas lights here in the US have little glass fuses in the plug too (since they use wire that's much too small to be protected by a 15A or 20A breaker). And hair dryers in the US often come with a little GFCI built in to the cord plug. So protecting at the cord plug is not a novel idea, and might save a lot of hassle this AFCI stuff causes.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
The Following User Says Thank You to tylernt For This Useful Post:
Old 05-14-2013, 10:22 AM   #50
Good point Ty...... A little better than my idea we run FMC as appliance cord
Old 05-14-2013, 08:49 PM   #51
Originally Posted by Jim Port View Post
Anne Arundel County does not have homeowner permits. The OP will need to hire someone with a license to perform the panel change. Also BGE does not allow anyone to cut their meter tags.
Thanks, Jim. I guess its time to start studying for a license...
"If you're going to do this work yourself, and I'm sure you are..."
Sirsparks, you were spot on.
"I have no idea what the top left feeders that don't appear to be breakered are... is there a subpanel involved somewhere... but if it's a feed... seems to me it should be breakered. Am I missing something??????"
Peter, from what i can tell, the top 4 slots are used to feed 90a to a sub panel for the furnace.
Mike, i cant send PM's until i hit 15 posts. send me your contact info.
thanks again everyone. im glad that i could at least "spark" a decent thread.
adis is offline   Reply With Quote
Old 05-14-2013, 09:05 PM   #52
i knew i shoulda moved to Virginia...
Old 05-14-2013, 09:11 PM   #53
Building tradesman
load calculations?
So we meet the 6 handle max with the Furnace, Range, Dryer, H2O heater, and last but not least a 50 amp 2 pole feeding the "other bus".
Now looking at the number of and type of circuits the existing lighting bus supplies I would venture to say there is actually a need to complete a load calculation before any type of planning or work is started. I did not run numbers but, 3000va for 2 ea sabc in the kitchen, 1500 for a sabc for the laundry, ac#3, dishwasher, disposal, microwave(is it an exh hood microwave?), how many sq feet is the residence?. Not as I say doing the number crunching, his main power for his home is a 50 amp service and that seems a bit undersized for everything listed and if not than borderline capacity wise. My 2 cents, new panel with main disconnect, branch breaker space in new panel with 2 new feeders for the 2 busses in the old panel. And wow, 90 amp for the furnace, think ground source heat pump and save by the minute.
dudleydoright is offline   Reply With Quote
The Following User Says Thank You to dudleydoright For This Useful Post:
adis (06-18-2013)
Old 05-14-2013, 09:12 PM   #54
Licensed electrician
Rewards Points: 1,766
I don't want to rain on your parade, but the license normally requires 4 or more years of documented experience in the trade before sitting for the test.
PM me if you need to discuss options.
Old 05-14-2013, 10:07 PM   #55
Thanks Jim, I was being facetious (shoulda used a smiley.) Can you PM me your info - i need 10 more posts before I'm allowed to PM.
Old 05-15-2013, 07:00 AM   #56
Dudley, it was common for those split bus panels to be at least 100 amps, 150 and 200 could be possible. The size of the service cable or conductors would need to be checked to see the service size.
Old 05-15-2013, 09:07 AM   #57
As Jim says... The GE (with two lighting 120 buses) is fed by two 50A doubles breakers... so you could say it has 100A to its lighting 120 circuts) can't remember #slots... but plenty, especially with 1/2 breakers.
The panel is 200 rated
What I can't remember is whether it accepts/rated to feed 240 from the lighting circuts... have to read it next time I see it.
Peter
Old 05-15-2013, 09:14 AM   #58
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
of course it would it is feed by 50 amp 2 pole right ??
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 05-15-2013, 09:25 AM   #59
Yes two two poles..... I referred to them as two 50A doubles.
as I recall.... not tandems and just 1 inchers handle tied (4 individual 1" breakers)
Old 05-15-2013, 09:30 AM   #60
Rewards Points: 516
still two poles or L1 and L2 or 2 120 volts 180 degrees out of phase ...
Garage Sub Panel Questions mscanlon01 Electrical 3 07-20-2011 10:03 AM
Old House Rewire finnimus Electrical 15 05-13-2011 10:39 PM
Renovating basement, main too full: sub panel plan, OK? renoman Electrical 6 08-18-2010 10:32 PM
Main Service Panel Full bobo Electrical 5 09-24-2007 07:13 PM
100A Panel is full...I Need more circuits redly Electrical 2 06-20-2005 06:26 AM
