Opinions On How To Add Slots To Full Panel - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-12-2013, 09:09 AM   #16
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
Originally Posted by usair View Post
Its a garage. Some of us use our garage for more than a place to park a car. My compressor takes a thirty amp so does my welder. The OP said he wanted to operate "tools" . Now it is important to match the receptacle to the circuit amperage so a thirty amp receptacle will be needed on a thirty amp circuit
30 amp 120 volt or 30 amp 240 volt ????
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
The Following User Says Thank You to Philly Master For This Useful Post:
Speedy Petey (05-12-2013)
Old 05-12-2013, 09:31 AM   #17
Rewards Points: 6,652
Have you ever seen a 30 amp single pole breaker in your life? I have never have, but you happen to find one, let me know. Of course you could take off one side of a double pole and make a mwbc 120v/30a circuit, but there are rare occasions that you would do that, and would need to know what you are doing.
Old 05-12-2013, 09:37 AM   #18
An old Tradesmen
Rewards Points: 7,760
http://www.bing.com/shopping/eaton-c...aker&FORM=HURE
Old 05-12-2013, 09:42 AM   #19
Rewards Points: 150
I,m old so I have seen several 30 amp single pole breakers I have a box full that we changed out for 30 amp GFI single pole breakers for shore power connections on a marina dock.
usair is offline   Reply With Quote
Old 05-12-2013, 09:47 AM   #20
Rewards Points: 756
Only from the guy who gave me a good sized arc flash by putting a 30A single pole on #14 wire because the 15A kept tripping. It's a long story that ended up with me flash blinded and cursing standing on two floor joists in a very dark attic.
Mark
busman is offline   Reply With Quote
Old 05-12-2013, 10:06 AM   #21
Rewards Points: 1,192
Square D QOB 130.We use them alot in computer rooms.
bobelectric is offline   Reply With Quote
Old 05-12-2013, 11:43 AM   #22
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 3,286
Strange the 30A single came up.
My daughter/husband bought their first home in SFrancisco last year.
It had previously been a rental and at one time was a "grow house"
Besides extensive lighting circuits in the garage, I pulled two 30A 120 singles out of her garage.
Don't know, but I'm guessing they were for some heavy duty portable type heaters.
Also found two hidden safe's.... unfortunately empty
MTN REMODEL LLC is offline   Reply With Quote
Old 05-12-2013, 12:02 PM   #23
I respect the conservative and safe advice discouraging a DIYer of getting in over their head, especially electrical because of the inherent dangers.
But by the same token, we all had to learn and install our first sub or service.
This OP, while admitting he's inexperienced, seems pretty intelligent and responsible in his planning and forethought. His questions, actually to me, seem to display his forethought and capability to undertake a project, even though a present lack of experience.
While I wouldn't recommend he undertake it based solely on tutelage from the internet, if he could find a knowledgeable local party to assist him, I think he could do it.
Just my opinion at this time.
And I sure would think the sub panel is unquestionably the best and easiest approach.
Peter
The Following User Says Thank You to MTN REMODEL LLC For This Useful Post:
adis (06-18-2013)
Old 05-12-2013, 12:45 PM   #24
Thanks for all the replies, i should have started from the beginning. My garage currently only has one 15a receptacle. I would like:
Circuit 1. a 120v circuit to run either my 20a MIG, or run both a (small) 14.5a compressor and a 10a wet vac at the same time. According to the MIG factory specs, it only requires a 20a service, but I have found that 20a breakers pop before I get near max duty cycle. I like to run the vac while i cut/grind/sand with the air tools to cut down on dust. So I thought a 30a circuit was appropriate.
Circuit 2. a 240v circuit to run various 220-240v hand/tabletop tools (saws, routers, drills, sanders) that I purchased when I lived in Asia. None of these require more than 10a, and a 20a circuit would be fine. I just felt that if in the future I upgraded to a bigger compressor or other pro-grade equipment that a 30a circuit would be more useful.
Main Breaker: I'd feel more comfortable knowing that I had this
Additional Future Slots: I will need them - the garage circuits are simply to give me the ability to create the need for more electricity throughout the house
Status: Main breaker panel is (essentially) full; I have no experience doing electrician's work
So, I guess my question is:
Given my requirements and the current status, what is the best way to address this challenge?
Allen, your suggestion is exactly what I was thinking: adding a sub panel, and moving slots from the main over to it. I think this is something that I can accomplish.
Pete, I appreciate your concerns, and thank you for your post. Also, I did not realize that 30a receptacles would be an issue. If 30a circuits are the solution for which I am looking, what are my options as far as plugs go?
Thanks again to everyone for your replies, and as before, all constructive input is welcome.
adis is offline   Reply With Quote
Old 05-12-2013, 12:49 PM   #25
Thanks Peter, that's very kind of you. Optimism and cynicism both have their places!
Old 05-12-2013, 01:02 PM   #26
jproffer's Avatar
Rewards Points: 716
He does not need to change out his entire panel.
Second question: How do I accomplish what I want? Subpanel or new main panel?
Third question: Can I maintain the existing wiring and simply add either the sub panel or new main in situ?
Seems to me he's wanting to pursue one of two possibilities...Subpanel or new main panel.
I wouldn't suggest either of these for his first electrical job.
Again, no offense to you adis...or to anyone else.
jproffer is offline   Reply With Quote
Old 05-12-2013, 01:58 PM   #27
You have to remember that what I did, most stuff was fuses for the protection. Only time we messed with breakers was down at the load centers, and the EM's handled those, since we dealt with the electronic and mechanical navigational/communication gear for my trade.
Old 05-12-2013, 06:01 PM   #28
Rewards Points: 1,532
I have seen some recreational vehicles that really want a 30 amp 120 volt circuit at the house or at a campsite to plug into although a plug adapter for a 20 amp receptacle is usually provided. It is not unusual to run a separate 30 amp 120 volt circuit (10 gauge wire) to a 30 amp receptacle in a workshop or garage for large 30 amp power tools.
The Following User Says Thank You to AllanJ For This Useful Post:
adis (06-18-2013)
Old 05-12-2013, 07:15 PM   #29
jbfan's Avatar
Rewards Points: 530
You need to get out more!
Old 05-12-2013, 11:24 PM   #30
Rewards Points: 512
If you're going to do this work yourself, and I'm sure you are, then purchase a new panel.
Do you own your home? If so, I would look into getting a permit and inspection by a licensed ELECTRICAL inspector.
Where are you located?
There are safe ways to do this, but you will have to take it slow and ask for advice at every point in the removal and replacement.
Take pics BEFORE and AFTER, both the Service panel, and the Meter Base, and upload your progress and questions at each stage.
And don't be afraid to question replies, especially from those of us who are NOT Professional Sparkys. If you're unsure of a reply, wait for a Pro.
TO the Pros: Why isn't there a Main Disconnect in this? Does the 6-throw rule allow this?
Edit: I found your location.
Installation is the Reverse of Removal.
The Following User Says Thank You to sirsparksalot For This Useful Post:
adis (06-18-2013)
Garage Sub Panel Questions mscanlon01 Electrical 3 07-20-2011 10:03 AM
Old House Rewire finnimus Electrical 15 05-13-2011 10:39 PM
Renovating basement, main too full: sub panel plan, OK? renoman Electrical 6 08-18-2010 10:32 PM
Main Service Panel Full bobo Electrical 5 09-24-2007 07:13 PM
100A Panel is full...I Need more circuits redly Electrical 2 06-20-2005 06:26 AM
