Opinions On Expanding Foam Around Outlets And Switches - Electrical - DIY Chatroom Home Improvement Forum
Old 02-03-2012, 08:16 PM   #1
Opinions on expanding foam around outlets and switches
Has anyone done it and are you satisfied with the results? My outlets and switches are quite drafty and I am thinking of taking this step to cut down on that.
I have several cans of minimal expanding foam sitting around doing nothing anyways....haha.
Michaelpro is offline   Reply With Quote
Old 02-03-2012, 08:23 PM   #2
Missouri Bound's Avatar
Pull out one of your switches or outlets and see if it's insulated BEHIND the box. If it is then use your foam to finish the perimiter. If that doesn't work you can buy those foam gaskets to put at the receptacle / switches. Those do work well, but foam insulation can't hurt.
Do you want it your way or the right way?
Old 02-03-2012, 08:59 PM   #3
Rewards Points: 6,652
I did that around mine, including putting 3m Window film over some windows in my living room, and it has helped. My furnace does not cycle that much, as it did before I did the foam around the outlets and windows.
Old 02-03-2012, 10:22 PM   #4
Did you guys use the normal foam like the stuff from Greatworks, or a latex based foam?
I've read that latex isn't as flammable as the polyurethane based foams. Does this really matter if it is going outside of the electrical boxes?
Wiring multiple outlets, switches and lights Bubski27 General DIY Discussions 3 11-09-2011 06:54 AM
switches and outlets kitty5568 Electrical 1 03-15-2011 11:31 PM
Replaced some switches and outlets, now some lights don't work DWooderson Electrical 3 02-02-2010 12:06 PM
Replaced outlets, now wall switches don't work? PittsburghPaul Electrical 3 08-09-2009 05:50 PM
replacing old outlets and switches Nailpounder Electrical 7 04-28-2008 09:36 AM
