Opinion On New Service Entrance Run - Electrical - DIY Chatroom Home Improvement Forum
Old 11-11-2009, 10:59 AM   #1
Opinion on new service entrance run
I'm in the midst of upgrading my service from 100 amp to 200 amp... my new load center is about 6 feet from the old one. My current meter is inside. I'm trying to at as much done as possible before I call the elec company to come out and kill the power to make the final connections. I'm going to move my meter outside, and have a couple of choices as to which route to run new service entrance line.
I think I'm leaning more toward option 1. But just wanted to be sure that there isn't any obvious problem with my basic layout. My city is on NEC 2008. According to docs on the elec company site, I have to install the meter at least 3 feet away from existing windows (which this new location will be).
Should I go through the trouble of conduit? Or would the standard SEU/SER type cable be sufficient. The new entrance to the home would be somewhere in the vicinity of where the blue and red lines meet along the bottom of the picture.
Also, I'm going to have to put a new hole in the side of my house to bring the new line in. What would be the best way to seal that hold back up? Can I just mortar around the cable, should I use some kind of expanding foam?
Opinion on new service entrance run-img_0261_2.jpg   Opinion on new service entrance run-img_0261.jpg
philipjcaputo is offline   Reply With Quote
Old 11-11-2009, 11:04 AM   #2
I would go a little further up the gable & then go straight down to the old entrance point
That will avoid that odd little jog at the top
Further back from the corner looks better IMO
Old 11-11-2009, 11:09 AM   #3
I agree, it would be nicer for the connect to be closer to the top of the root peak... but I have to be 3 feet from any window (and 12 feet above the ground) where the connection between my service entrance line and the power company's line.
Old 11-11-2009, 04:23 PM   #4
Electrician
Rewards Points: 800
Call the inspector and the power company and see where they want the service point. That is usually done around here before doing a service, better to have them on your side before doing all the work.
darren is offline   Reply With Quote
Old 11-11-2009, 06:23 PM   #5
Rewards Points: 502
yes, call POCO. It'll be a free call and they'll come out and give you input on what they are looking for.
Same thing with the inspector, they do free consulting in your county.
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
Old 11-11-2009, 07:58 PM   #6
Journeyman Wireman
Rewards Points: 150
Use the spot closest to the front, go straight up, drill a hole through the overhand and use a neoprene roof jack (boot). That way you can get your elevation above the roof line.
[IMG]file:///C:/Users/Dolores/AppData/Local/Temp/moz-screenshot-1.png[/IMG][IMG]file:///C:/Users/Dolores/AppData/Local/Temp/moz-screenshot-2.png[/IMG]
Jupe Blue is offline   Reply With Quote
Old 11-11-2009, 09:11 PM   #7
Electrical Contractor
kbsparky's Avatar
Try to keep the new service drop as straight and neat as possible.
You can put it on the other side of the point of attanchment, as long as the conductors reach, it should not matter!
Here is my suggestion:
-KB
Old 11-12-2009, 10:59 AM   #8
Rewards Points: 204
Can you have it installed underground? They (POCO) did mine for free. Never make a hole in the roof unless you have too. If you have the clearance stay below the roof.
If it worked before you worked on it. You did something wrong.
Old 11-13-2009, 01:09 PM   #9
still remodelling....
Wow - wish I could have had mine moved underground for free! ComEd wanted to charge 'up to $3000' for them to do it, or reduced if I did some of the ground work (trenching, laying conduit), but would still have charged a min of $1200 for transferring from above ground to below ground.
Just last week I upgraded from 100A to 200A, chose to move service entrance point clear across to the other side of house (the service mains were sagging way to close to ground and were cutting across the yard). Now the lines are tight, going along my property line, and the ComEd work was free (there's a small story to that one, but otherwise they wanted to charge $500 for it).
Interesting thread... I'd say if you don't need to, keep the work as simple as possible. Don't complicate it for the sake of complicating it. Also, once it's all said and done and a few months/years go by - you'll never really notice either option A or B. "K.I.S.S."
Eusibius2 is offline   Reply With Quote
Old 11-13-2009, 01:23 PM   #10
300zx's Avatar
Post
They charge by the foot here also!
300zx is offline   Reply With Quote
Old 11-13-2009, 02:57 PM   #11
This should be sealed with Duct Seal Putty I would think. That's what sparky's seal every hole they drill with!
Salem747 is offline   Reply With Quote
Rewire 200A service entrance OffRoadAudio Electrical 4 08-24-2009 02:27 PM
Underground service entrance cable requirements. kgt55 Electrical 9 06-22-2009 06:55 AM
Service entrance dcwestcott Electrical 3 03-09-2009 06:11 PM
Grounding for two service entrances to same house. jogr Electrical 18 09-24-2008 10:31 AM
Melted Service Entrance Wire in Panel theatretch85 Electrical 13 08-22-2008 10:37 AM
