Operating Fluorescent Light - Electrical - DIY Chatroom Home Improvement Forum
Old 03-16-2014, 11:19 PM   #1
Angry
Operating fluorescent light
I've got an older fluorescent light fixture in the bathroom of the house I recently bought and I can't seem to figure out it's operation! There are two "prongs" on each end that appear to be what is used to turn the light on/off, but for the life of me I can't get it to work anymore. I did have it come on once, but now I can't figure out the combo (sequence?) I used and can't get it to turn on. Help! Any suggestions are appreciated!
Fry63 is offline   Reply With Quote
Old 03-16-2014, 11:45 PM   #2
Rewards Points: 14,306
No picture of the light.
No idea what "prongs" your looking at. On the ends of the bulbs?
Is there black areas on the ends of the bulbs?
Is it 4', 8', ciruler, horse shoe shaped?
Fry63 (03-17-2014)
Old 03-17-2014, 12:11 PM   #3
The "prongs" I'm talking about are on both ends of the fixture itself, not the bulb. The bulb is approx. 2 ft long with green ends. It appears that you are to push on the "prongs" on the end of the fixture to turn on/off the light, but the sequence eludes me. Sorry I don't have a picture; I'll work on that. Electrical issues aren't my forte, so please bear with me! Thanks!
Old 03-17-2014, 12:22 PM   #4
I am
Guessing here..
The prongs hold the bulb and make electrical contact.
green ends sounds like a new bulb.(or good for saint pattys day)
Sounds like ballast and or starter and someone replaced bulb but that was not the problem..
you should't have to play with the bulb to turn it on and off (guess you got lucky once and it lit)
on/off should be from a switch on the fixture or in/on the wall.
UnclePhil is offline   Reply With Quote
Old 03-17-2014, 12:23 PM   #5
joed's Avatar
Rewards Points: 13,734
Almost all fluorescents I have seen simply turn on with a switch. The only one that didn't was a desk lamp and you had hold the button down until the lamp started to glow then let go. Then push it again to turn off.
Old 03-17-2014, 12:24 PM   #6
I am
Prongs?
if so, they are sockets..
Old 03-17-2014, 07:48 PM   #7
Rewards Points: 115
if you have to push on the prongs(sockets) to get lamp to light you have loose contacts. you should have a switch someplace to control the light. either on the fixture itself or on a wall. lamps should light up without having to play with sockets.
pokey is offline   Reply With Quote
Old 03-18-2014, 12:47 AM   #8
dmxtothemax's Avatar
Rewards Points: 5,608
Whats this " combo sequence " that you speak of ?
If its a floro light? then there could be several problems !
What type of fixture is it ?
size, shape, brand, age ?
Ballast ? Starter ? Tomb stones ? loose wires ?
Tell us more ?
dmxtothemax is offline   Reply With Quote
Old 03-18-2014, 03:48 PM   #9
Oso954's Avatar
Rewards Points: 1,654
If this is a vanity light near the mirror, I wouldn't waste any time with it.
Get a new fixture and replace it.
Oso954 is offline   Reply With Quote
Old 03-18-2014, 04:19 PM   #10
Rewards Points: 1,192
Maybe the switch gets turned ,not pushed.
bobelectric is offline   Reply With Quote
Old 03-19-2014, 05:39 AM   #11
Cletis's cousin ?
Tags
fluorescent light
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 04:28 PM
Replacing circular fluorescent light fixture - grounding issue DynamoDan Electrical 13 05-10-2013 03:57 PM
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 06:32 PM
direct wiring fluorescent light amakarevic Electrical 7 01-11-2010 09:03 PM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 07:52 PM
