Open Neutral Problem, Please Help - Electrical - DIY Chatroom Home Improvement Forum
Old 02-11-2012, 05:59 AM   #1
open neutral problem, please help
Hi,
I have an open neutral problem within CU from the main-power supply to FCU (3A) to boiler. The voltgages of L(brown) and N(blue) on my boiler both appears as 238 v against earth. I tried to find where the neutral is open. I disconnected the three main-power lines (one red supposed to be live, one black supposed to be neutral and the yellow/green supposed to be earth) on the FCU (the other three lines to boiler also disconnected from FCU). I checked the voltage of these three lines from main power against the other earth which is grounded by connection to the metal panel of the boiler in the end.
Red the live against earth on boiler: 238
Black the neutral against earth on boiler: 147
yellow/green the earth from main-supply against earth on boiler: 178
Black against yellow/green the earth from main-power: 18
Black against red: 51
Red against yellow/green the earth from main-power: 36
I did some more tests. I connected both earths in FCU together and grounded it by connection to the metal panel of boiler.
Red against earth: 238
Red against black: 174
Black against earth: 37
I get confused now. Is the lines from main-power to FCU ok? Does the test suggest a short cut between the live and neutral somewhere from the air-switch box? why the voltage between the two earths isn't 0? Does it mean the earth from main-power isn't grounded?
Please help me. Thank you so much
beresford is offline   Reply With Quote
Old 02-11-2012, 06:29 AM   #2
Electrical Contractor
kbsparky's Avatar
What country are you in? What is your nominal supply voltage/frequency?
-KB
Old 02-11-2012, 06:46 AM   #3
Hi, thanks
I am in UK. I assume the residential electric supply is 240V/50HZ. I did more test and edited my poster above a bit.
open neutral mrs york Electrical 2 06-22-2011 08:07 PM
Bond subpanel Neutral directly to SE neutral using split bolt? Sierevello Electrical 1 01-30-2011 08:08 PM
Electrical connections TazinCR Electrical 11 01-07-2009 07:10 PM
Will reverse polarity trip breaker?? Duane 70 Electrical 60 12-05-2008 10:18 PM
Help if it's not too late!! Cyndi Electrical 255 10-10-2008 09:18 PM
