Open Neutral On Dryer...dryer Won't Work - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 02-19-2012, 10:51 PM   #31
Originally Posted by Stubbie View Post
The motor and lights in a dryer are 120 volts so without neutral these will not work. The heater is the only thing that operates at 240 volts.
I assuming when you tested open neutral you meant your getting zero or near zero volts when testing from a hot leg to neutral?
If the outlet is wired correctly it should look like this
120v +/- go for all res voltage?
Hardway is offline   Reply With Quote
Old 02-19-2012, 11:07 PM   #32
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Yeah it can take some real ingenuity when you work alone and no help. I don't generally like LB's unless they are being used to go thru a wall and the panel is very close after that. Some times it helps to use adapters and upsize the LB to the next size.
Posted some pictures of my success could have been better but I have seen much worse.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 02-20-2012, 03:16 AM   #33
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Yes, there may be some areas that are still 110 and 220.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
The Following User Says Thank You to Stubbie For This Useful Post:
Hardway (02-20-2012)
Unused ground lead as neutral? ramatsu Electrical 13 01-10-2012 08:44 PM
Another dryer/plug question STEVE IN OC Electrical 16 12-23-2008 10:58 AM
dryer timer auto cycles don't work mikedudl Appliances 6 04-29-2008 08:48 PM
It serves me right - now my dryer won't work Leah Frances Appliances 3 04-29-2008 03:42 PM
Hot / Ground Reversed & Open Neutral Shirtpocket Electrical 16 06-05-2007 02:06 PM
