Open Neutral On Dryer...dryer Won't Work - Electrical - DIY Chatroom Home Improvement Forum
Old 02-19-2012, 07:53 PM   #1
open neutral on dryer...dryer won't work
I installed a brand new stack unit washer dryer yesterday. Customer called and said dryer came on (lights only) but drum wouldn't turn, then lights went off and now doesn't work at all. I checked it out today and found the following: 4 wire cord was indeed installed correctly on machine. 4 wire outlet tested as having an "open neutral" but 4 wire outlet was wired properly (each conductor run to its respective screw on outlet). 30 amp dryer circuit appears to be wired correctly in panel box (both hot legs to circuit breaker and neutral and ground to each separte bar).
Question: Will dryer normally run if the outlet has an open neutral?
Any idea why the outlet would show an open ground when it appears to be wired properly at outlet and at circuit breaker?
Why would dryer lights come on but unit not work when it has a full 240 volts coming to it?
By the way, I tested the outlet by plugging in another brand new dryer today and it didn't work either, so it's definitely something to do with outlet, not the dryer.
inspectorman is offline   Reply With Quote
Old 02-19-2012, 08:03 PM   #2
Are you sure the 30 amp dryer outlet was wired correctly? Make sure that the white neutral is installed to the correct terminal on the outlet. My first assumption is that the neutral is landed on the wrong terminal.
After you check, and if that's not the problem, start measuring the voltages at the outlet.
hawkeye11 is offline   Reply With Quote
The Following User Says Thank You to hawkeye11 For This Useful Post:
inspectorman (02-19-2012)
Old 02-19-2012, 08:09 PM   #3
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Electronic dryers can do some really crazy stuff when missing the neutral. I hear it can ruin the appliance.
rrolleston is offline   Reply With Quote
The Following User Says Thank You to rrolleston For This Useful Post:
Old 02-19-2012, 08:21 PM   #4
Thanks Hawkeye,
I checked the outlet, and yes, the 2 hotlegs were run to each terminal screw behind the Hot leg plug slots, and the ground and neutral were each run to their respectiver terminals. All screws were tight. Homeowner also said the last dryer worked fine. I'm at a loss here.
Old 02-19-2012, 08:24 PM   #5
rrolleston's Avatar
I would suggest they get an electrician to fix the open neutral. And possibly they need a new dryer because open neutrals and newer dryers seem to cause a lot of trouble.
Old 02-19-2012, 08:27 PM   #6
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Im guessing it has a 120v motor or controls
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
The Following User Says Thank You to plummen For This Useful Post:
Old 02-19-2012, 08:29 PM   #7
Code05's Avatar
Rewards Points: 1,104
Thanks Hawkeye,
Are all your voltages correct?
L1-L2=240v
L1-N=120v
L2-N=120V
Same for (L1 or L2)-G=120v
N-G = 0 and continuity.
Both at panel and receptacle?
Code05 is offline   Reply With Quote
The Following User Says Thank You to Code05 For This Useful Post:
mpoulton (02-20-2012)
Old 02-19-2012, 08:31 PM   #8
Code05's Avatar
Open neutrals cause problems everywhere...........
Old 02-19-2012, 08:33 PM   #9
rrolleston's Avatar
I have seen them fry the board when missing a neutral.
Old 02-19-2012, 08:36 PM   #10
All I had with me today was a basic 240 volt plug in tester, so I couldn't measure the voltage. I install appliances for a major retailer, and just hadn't run into this before. They limit what I can do, but my curosity is killing me regarding this problem. My boss told them to get an electrician to check out the circuit, but I was hoping to gain some insight on this for future reference. My primary question is...can an appliance run on just the 240 volts without a closed neutral?
Old 02-19-2012, 08:38 PM   #11
rrolleston's Avatar
One thing the original poster could try is using the dryer somewhere else. Maybe another house. And don't send them a new dryer till they get the outlet fixed. I like having a dryer outlet in my garage so I can test dryers and work on them.
Old 02-19-2012, 08:39 PM   #12
rrolleston's Avatar
Lesson learned outlet not testing right don't plug it in.
Old 02-19-2012, 08:54 PM   #13
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
The motor and lights in a dryer are 120 volts so without neutral these will not work. The heater is the only thing that operates at 240 volts.
I assuming when you tested open neutral you meant your getting zero or near zero volts when testing from a hot leg to neutral?
If the outlet is wired correctly it should look like this
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
The Following User Says Thank You to Stubbie For This Useful Post:
zappa (02-19-2012)
Old 02-19-2012, 08:56 PM   #14
The only thing that will operate on 240 V is the heating element. The electronics, motor, etc. need 120 via the neutral to operate.
Old 02-19-2012, 08:59 PM   #15
plummen's Avatar
It will only run on 240v if it has only 240v loads on it,120v loads will require a neutral to complete the circuit
Unused ground lead as neutral? ramatsu Electrical 13 01-10-2012 07:44 PM
Another dryer/plug question STEVE IN OC Electrical 16 12-23-2008 09:58 AM
dryer timer auto cycles don't work mikedudl Appliances 6 04-29-2008 07:48 PM
It serves me right - now my dryer won't work Leah Frances Appliances 3 04-29-2008 02:42 PM
Hot / Ground Reversed & Open Neutral Shirtpocket Electrical 16 06-05-2007 01:06 PM
