Open Neutral - Electrical - DIY Chatroom Home Improvement Forum
Old 06-22-2011, 07:15 PM   #1
open neutral
two receptables do not work. they inicate open neutral. circuit breaker ok. now what
mrs york is offline   Reply With Quote
Old 06-22-2011, 07:48 PM   #2
Licensed electrician
Rewards Points: 1,766
You need to look for a loose white wire either at the first non-working receptacle or the last working receptacle. If the wires are stabbed in the back it would be better to make a loop and place it clockwise under the screw and tighten the screw.
Old 06-22-2011, 08:07 PM   #3
Too Short? Cut it Again!
I know you tested the breaker but did you check to make sure the neutral to the box and for that circuit was tight?
Detached Garage Sub Panel Grounding Q integlikewhoa Electrical 15 03-12-2015 07:02 PM
Open neutral, hot & grd reveresed? th3chainrule Electrical 7 01-24-2011 01:42 PM
Induction Cooktop, no neutral (?!) andersol Electrical 7 09-28-2010 03:47 PM
240 volt load/appliance and ground vs neutral kgize Electrical 7 04-22-2010 11:40 PM
MWBC bad neutral test results! kbsparky Electrical 15 04-06-2010 08:44 AM
