Open Grounds 6 Recepticals. - Electrical - Page 5 - DIY Chatroom Home Improvement Forum
Old 03-01-2013, 10:50 AM   #61
The 1st photo has two wires entering the panel in a grommet together. They have a silver and black casing. The one in question is the one in the back. In pic 2 the 2nd down from the top are the ground wires that are twisted together.
Open grounds 6 recepticals.-img_6688.jpg   Open grounds 6 recepticals.-img_6689.jpg
commanche is offline   Reply With Quote
Old 03-01-2013, 11:06 AM   #62
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Unless I'm missing something, the silver cable is old ungrounded romex.
Old 03-01-2013, 12:07 PM   #63
It's hard to see but on the one behind the cable in the front there is a ground wire there. But if you look closly right below the white wire you can see it.
How to best filter water for open loop geothermal Jim S. HVAC 6 07-05-2012 04:12 PM
Open pressure switch on furnace Dale0202 HVAC 4 01-26-2011 10:35 PM
Keeping Door Propped Open dgreco3917 Carpentry 6 09-29-2009 09:19 PM
Several open grounds gordyPA Electrical 5 06-25-2009 10:24 AM
New ball valve leaking half open? sz8 Plumbing 5 01-05-2007 10:46 PM
