Open Grounds 6 Recepticals. - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 02-26-2013, 09:56 PM   #31
stubbie the wire is twsted around other grounds and then grounded as a group to the panel.
commanche is offline   Reply With Quote
Old 02-26-2013, 09:58 PM   #32
Rewards Points: 121
I think I would check the ground wire in your first box very carefully, it could be be broken. I was replacing some switches recently and some of the ends of the wires just broke as I was removing them from the switch. Still working but on the verge of becoming an open circuit.
readar is offline   Reply With Quote
Old 02-26-2013, 09:59 PM   #33
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Originally Posted by commanche View Post
stubbie - I do not own a voltage meter, however I do have a 2 wire tester that checks for the prescense of voltage. i noticed when i go across from hot to common I have a strong light, but when I go from the ground to the hot it stll lights up but it is dimmer. Don't know if that helps at all.
Extremely poor connection somewhere or a nearly broken/damaged ground wire. If you cannot find it you have some options ... as i assume your worried about safety.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 02-26-2013, 10:03 PM   #34
Stubbie the ground wire is twisted around with other grounds, and then grounded as a group.
Old 02-26-2013, 10:11 PM   #35
Stubbie Yes I am concerned about safety. Is there any reason to separtate the ground in the panel that are twisted together, and make a separate ground junction in the box? What would be the best way to do that? it is not too close to the grounding bar.
Old 02-26-2013, 10:11 PM   #36
UAW SKILLED TRADES
Stubbie's Avatar
Ok I've seen that many times. Is it a wirenut that is used to join all the grounds together and then a single wire to the screw. And is this screw a terminal strip involving several screws for the neutrals and grounds or is this only bare ground wires to a single screw in the panel metal.
Stubbie
The Following User Says Thank You to Stubbie For This Useful Post:
commanche (02-26-2013)
Old 02-26-2013, 10:14 PM   #37
reader my panel is in my garage , and all of the ceiling and walls have drywall on them making for not easy wire tracing. Do you have a trick to use?
Old 02-26-2013, 10:18 PM   #38
UAW SKILLED TRADES
Stubbie's Avatar
You will need a continuity tester but this will only help you isolate the problem area.
Stubbie
Old 02-26-2013, 10:21 PM   #39
Yes Stubbie Yes Yes Yes and Yes however instead of the grounds being together with a wire nut, they are twwisted together and then run as a group to the terminal grounding strip that includes comons and grounds on the same strip. which I called a grunding bar.
Old 02-26-2013, 10:22 PM   #40
stubie I do have a continuity tester.
Old 02-26-2013, 10:24 PM   #41
UAW SKILLED TRADES
Stubbie's Avatar
Do you have the resources to post a picture?
Stubbie
Old 02-26-2013, 10:25 PM   #42
UAW SKILLED TRADES
Stubbie's Avatar
On second thought my last advice was careless I don't think you should mess inside the panel like I suggested.....but my point was you need to be sure every ground is solidly connected. The way the equipment grounds are now is a code violation
Stubbie
Old 02-26-2013, 10:33 PM   #43
stubbie How exactly woudl I do that. These are older wires too. Woudl I just cut the ground wire out, wire nut it to a new bare wire, and run it to the groundimg bar?
Also what would we be accomplishing here? Would this be solving the problem?
Old 02-26-2013, 10:35 PM   #44
UAW SKILLED TRADES
Stubbie's Avatar
See my edit on previous post but yes that was where I was going. I think you should let an electrician do that kind of work.
Stubbie
Old 02-26-2013, 10:35 PM   #45
Stubbie I did check continuity on that wire between the main panel and that wire and it tested good.
How to best filter water for open loop geothermal Jim S. HVAC 6 07-05-2012 05:12 PM
Open pressure switch on furnace Dale0202 HVAC 4 01-26-2011 11:35 PM
Keeping Door Propped Open dgreco3917 Carpentry 6 09-29-2009 10:19 PM
Several open grounds gordyPA Electrical 5 06-25-2009 11:24 AM
New ball valve leaking half open? sz8 Plumbing 5 01-05-2007 11:46 PM
