-   -   open ground power loss (http://www.diychatroom.com/f18/open-ground-power-loss-118398/)
scooter91 09-26-2011 08:33 PM
I have 5 outlets on one circut and 5 on another with all 10 on a split breaker. 5 out of the 10 do not have an open ground but they all are reading 108v. The other five out of the ten replaced are reading open ground. I am not an electric person by trade. I am confused and frustrated. HELP:censored:
a7ecorsair 09-26-2011 08:42 PM
:mad:
What are you using that says you have an open ground?
Split breaker - is this two breakers next to each other with a tie so they both operate together?
You have a meter so test all the receptacle and see what volt level you have.
How old is the house?
AllanJ 09-27-2011 08:00 AM
You can have a bad neutral that in turn can cause damage to electronics (televisions, computers, microwaves, etc.) Unplug all electronics until you find and fix the problem or have a circuit that holds steady at about 120 volt to plug the electronicds into. Does the 108 volts change depending on what appliances you are using (means a bad neutral)? Are any receptacles reading the correct 120 volts at the same time some reading 108 volts (problem is inside your house as opposed to possibly out on the utility pole)? Are some outlets reading well above 120 volts (definitely a bad neutral somewhere)?
scooter91 09-27-2011 08:42 AM
I bought one of those three pronged testers that have the 2 amber lights an a red light. My multi meter shows all ten of these outlets at 108v. the rest of the house is at 120v. The house is only 11 yrs old.
a7ecorsair 09-27-2011 09:13 AM
If the rest of the house shows 120 V then you have this Multiwire Branch Circuit wired incorrectly somewhere.
scooter91 09-27-2011 11:05 AM
Before I left for work I checked a couple of other outlets and they showed 114-117v. All circuts have been checked and they are all fine. All of my large appliances like water heater and washer dryer wont even work anymore.
jbfan 09-27-2011 11:11 AM
Now it is time to call the power company to check the incoming power!
You may have lost a leg of your service.
scooter91 09-27-2011 11:16 AM
I will call thanks
