Open Ground? Cornfused - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-29-2007, 01:20 PM   #16
" Euro " electrician
frenchelectrican's Avatar
Originally Posted by JRoot View Post
Thanks for all the helpful info, the garage wiring is fixed, old knob & tube is gone.
I ran the new powerline underground via conduit.
I removed the old overhead wires, and now I have the old wires still coming through the wall at the house. I am planning on putting in an outdoor receptacle here, using the same wires that once went out to the garage. There are 5 wires coming out of the house, and I just wanted to see if anyone knew what to make of this. I havent had a chance to start testing them, but I have never come across this 5 wire configuration. The garage was not wired for 220V or anything.
Any ideas? Ideas on how to start making sense of the 5 wires once I have a chance to test them?
i really recomoned that old 5 wire set up is aboned and capped off properly
to make a quick summery on this.
I know for sure 2 is for power but here is the joker of the day the other 3 is for 3 way switching circuit but the way it hook up it can be very dangerous what we called " California 3 way " or "Carter 3 way " or Farmer 3 Way those few of those are actally illegal way back from 30's until now the reason why i say illegal set up because one of the wire will be switching either hot or netual to the light socket and what will happend that one of the 3 way switch the power to the light willbe either hot or netual depending on which way the 3 way switch ran therefore what will happend is that the light socket shell will be either hot or netural depending on how it switched.
that the reason why we [ most electricicans ] strongly recomend to abaoned the old system.
Merci , Marc
P.S. the oddball 3 way switching is no diffrence between the North American vs Europen verison both end up the same result so just let you know on this one
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
12v diff between ground and neutral at panel am9518 Electrical 7 02-25-2008 06:28 PM
Ground rod blues!!! ra_doliv Electrical 8 09-02-2007 11:48 PM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 06:30 PM
New ball valve leaking half open? sz8 Plumbing 5 01-05-2007 10:46 PM
