Open Ground 6 Outlets On Same Circuit. - Electrical - DIY Chatroom Home Improvement Forum
Old 02-24-2013, 07:48 PM   #1
Open ground 6 outlets on same circuit.
I have found 6 receptacles on the circuit, all of them open ground. I have rechecked the grounds and commons in the main panel, and actually tightened all of them again. Didn't find anything amis at the main box. Two of the recep boxes did not have grounds, so I fixed them, and actually replaced all 6 receptacles. Still have the issue. I checked every switch that we have and nothing appears to be on that circuit. It is all receptacles so far. Is that normal? I even checked all of the motion sensor lights , and nothing included in my circuit.
Any ideas out there? Even though the breaker has not tripped - could it have gone bad?
commnche is offline   Reply With Quote
Old 02-24-2013, 07:51 PM   #2
" Euro " electrician
frenchelectrican's Avatar
You may have to check the junction box either in basement or in attic and also check the light switch location as well to make sure you have good ground connection.
What type of cable it have in there now ? NM or BX or other ??
Merci,
Marc
Old 02-24-2013, 08:18 PM   #3
They are all 110v receptacles only. I foumd no on-off switches on the circuit.
Old 02-24-2013, 08:59 PM   #4
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
As french stated, odds are there's a ground loose in a junction box somewhere.
sublime2 is offline   Reply With Quote
Old 02-24-2013, 09:04 PM   #5
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
How did you "fix" two boxes that didn't have grounds?
The Following User Says Thank You to k_buz For This Useful Post:
Stubbie (02-24-2013)
Old 02-24-2013, 10:08 PM   #6
There were no ground wires on the ground screws of the receptacles. I used the wires inside the box to go to the screws and also ran a ground wire to the metal boxes they are in. I basically copied one of my good outlets.
commanche is offline   Reply With Quote
Old 02-24-2013, 10:32 PM   #7
K buz is there any way that a breaker went bad, and didn't trip, causing the open grounds in 6 boxes? Also is there any reason to check other circuits in the house. These were the only ones so far that showed on my Snap It tester, and they are all on the same circuit?
Old 02-24-2013, 10:34 PM   #8
k_buz's Avatar
No, the breaker has 0 effect on the grounds. This circuit is either tied into an ungrounded circuit or the ground connection has not been properly made in a junction, device, or fixture box.
commanche (02-24-2013)
Old 02-24-2013, 10:41 PM   #9
Should I really be checking out any of my other receptacles if they are showing good on my tester?
Old 02-24-2013, 11:09 PM   #10
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
I'm not much of a fan with those receptacle testers, do you know which breaker in your panel protects the circuit these open ground receptacles are on?
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 02-24-2013, 11:13 PM   #11
stubbie - it is giving me good readings everywhere else in the house. Yes I do know which breaker it is on.
Old 02-24-2013, 11:34 PM   #12
UAW SKILLED TRADES
Stubbie's Avatar
I asked because I was'nt sure if you had 3 wire romex. The panel is the best place to tell if you do or dont. I read the other post and it says you have 3 wire romex which I assume means hot , neutral and bare ground. I also assume that the circuit in question shows these three wires in the circuit breaker panel?
Stubbie
Old 02-25-2013, 12:07 AM   #13
Stubbie - yes to all.
Old 02-26-2013, 09:58 AM   #14
Stubbie - I was in the UAW too. Local 1069 for 10 years.
Tripping breakers,neutrals,120 volts and 240 volts OH My!!! Stubbie Electrical 17 06-11-2011 07:09 AM
open circuit unknown location / voltage leakage fishmanflats Electrical 4 12-23-2009 10:04 PM
1990 Bounder Motorhome 3 prong outlets actally have no ground connected!! Help! Holering Electrical 5 03-30-2009 01:59 PM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 07:30 PM
? on 20A circuit / outlets / #of remhed Electrical 2 05-15-2005 09:55 AM
