Open Ground... - Electrical - DIY Chatroom Home Improvement Forum
Old 07-19-2013, 09:37 PM   #1
Rewards Points: 85
Open Ground...
Hi everyone...
Hope you all on the east coast are dealing with this crazy heat well...
Helping a friend out with his wiring and my plug-in tester states he's got an open ground issue. We pulled the outlet and the wiring is old. Cloth.. With tar coating. No bare or "green" ground wire. So how should we ground the outlet since I would have to tear out the drywall all the way to the panel to reach it to run a ground cable?
Thanks!
JohnC20 is offline   Reply With Quote
Old 07-19-2013, 09:53 PM   #2
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 3,390
John... Basically you've got a two wire ungrounded system.
To ground that sysyem, your choices per Nec are to rewire with a ground, or there is a exception whereby you can just fish a supplimental ground wire... have to find and refer you to all the restrictions on that one.
To make it safer, but still ungrounded, you can put in GFI's, pursuant to certain NEC req... have to find that one rather then spell it all out.
Best
MTN REMODEL LLC is offline   Reply With Quote
The Following User Says Thank You to MTN REMODEL LLC For This Useful Post:
Philly Master (07-20-2013)
Old 07-19-2013, 09:55 PM   #3
Rewards Points: 85
Best
Thanks for the reply! I appreciate thst
Old 07-19-2013, 10:06 PM   #4
Electrical Enthusiast
Rewards Points: 504
In addition to MTN remodel's good post...
be aware that some older metal boxes don't accommodate the large size of GFCIs very well.
Some big box stores still sell two prong ungrounded receptacles. Not sure of the legality of this, but it's probably better than having a receptacle with a ground installed on an ungrounded circuit.
If you decide to tear out drywall, I would probably run a new grounded cable, simply due to the current cable's age. But that's just me.
Kyle
Kyle_in_rure is offline   Reply With Quote
Old 07-19-2013, 10:14 PM   #5
Kyle's right... and its permissabe to replace an existing two prong with 2 prong... they get about $3 for that old recep.
And oh boy.... is Kyle right on those old metal boxes... tighter than a XXXXXXX strike that.
Also, your box feed wires may be very short and the old soldered/taped splice.... real problem/PIA.
Good luck... I'll try to find the NEC ref's on two wire and grounding/GFI options tommorrow.
Best
Old 07-19-2013, 11:02 PM   #6
Rewards Points: 6,652
Kyle
The Leviton Slim is about the only GFCI that will fit into the old boxes. http://www.amazon.com/Leviton-X7599-.../dp/B0048WPV4Q
The Following User Says Thank You to gregzoll For This Useful Post:
Kyle_in_rure (07-19-2013)
Old 07-20-2013, 09:54 AM   #7
Maybe Greg thought that there WAS a ground wire, and the receptacle was reading "open ground" because of that.
Boy... That's a pretty cool tester that can tell you you don't have a GEC... mine will only tell me I don't have an EGC
Best
Old 07-20-2013, 06:31 PM   #8
Mods.... I'm pretty sure you won't.... but please don't close this untill I can find the thread that so well outlines the OP's options of either grounding or GFIing his two prong/two wire system.
It was about 2 months ago, but I can't find it yet.
Best
Peter
Old 07-20-2013, 06:45 PM   #9
An old Tradesmen
Rewards Points: 7,816
Never be too sure. LOL
Thread cleaned up.
Old 07-20-2013, 06:47 PM   #10
Rewards Points: 504
Thread cleaned up.
I see that
2 Similar GFCI, but one tests open ground crescere Electrical 40 08-28-2012 09:19 PM
open ground uj1223 Electrical 6 06-08-2011 10:35 PM
Open Ground in Non Daisy Chained Outlet Circuit RileyRR Electrical 2 05-18-2011 02:00 PM
gfis w open ground brokenhammer Electrical 3 03-24-2010 08:37 AM
Open Ground Remedy? gksmith6 Electrical 5 01-04-2008 06:32 PM
