Open Ground - Electrical - DIY Chatroom Home Improvement Forum
Old 06-08-2011, 02:03 PM   #1
Question
open ground
i am using a receptacle test on my outlet and getting "open ground" error. i see there are 3 hot wires and 2 nuetral wires. 1 hot wire is connected to the ground terminal. would this mean i have 3 hot wires and no ground???
uj1223 is offline   Reply With Quote
Old 06-08-2011, 02:05 PM   #2
Are u sure its 5 wires in total or 3 wires connected to the receptacle?
Danny Mai is offline   Reply With Quote
Old 06-08-2011, 02:18 PM   #3
Civil Engineer
Rewards Points: 4,854
You need to get a voltage tester. I doubt that a hot is connected to a ground, that would be a dead short unless the ground is in fact not grounded, in which case it would be an open hot, very dangerous. Best way to check is to measure voltage to ground and voltage to neutral on each of the wires.
Old 06-08-2011, 02:21 PM   #4
yes its 3 black and 2 white, i just put a continuity tester on it, all 3 black are hot, i am assuming i have no ground, how would i ground this properly
Old 06-08-2011, 04:03 PM   #5
Semi-Pro Electro-Geek
Rewards Points: 2,970
If there are no ground wires in the box (older, ungrounded wiring), then there is no easy way to ground it. The safe and code-compliant solution is to replace the receptacle with a GFCI. Wire it so the incoming power (one of the hots and one of the neutrals - and you have to use the right ones!) goes to the "line" side, and the other hots and neutrals go to the "load" side. One note, though: it doesn't make sense to have three hots and two neutrals. Can you explain in more detail how these are connected? Is one half of the receptacle switched?
mpoulton is offline   Reply With Quote
Old 06-08-2011, 04:08 PM   #6
Rewards Points: 1,646
A continuity tester wouldn't be the right tester; I think a volt meter or 120 v AC test light would be more useful and safer IMO.
bob22 is online now   Reply With Quote
Old 06-08-2011, 10:35 PM   #7
I=E/R
a7ecorsair's Avatar
Are you telling us that the receptacle has two straight pins and one U shaped pin with a black wire connected to the green grounding screw on the receptacle?
a7ecorsair is offline   Reply With Quote
Open Ground in Non Daisy Chained Outlet Circuit RileyRR Electrical 2 05-18-2011 02:00 PM
Attach #4 Copper to Neutral/ Ground Lug Sierevello Electrical 3 01-29-2011 01:04 AM
gfis w open ground brokenhammer Electrical 3 03-24-2010 08:37 AM
sub panel ground and neutral daddyrabbit Electrical 3 01-29-2010 06:49 AM
Open Ground Remedy? gksmith6 Electrical 5 01-04-2008 06:32 PM
