Open Circuit
any junction boxes on this circuit? Some DIYers simply wire nut connections together.
It is important to understand when splicing, pigtailing, etc, that wire nuts are not enoughto hold wires together.
Check any connections in outlet boxes and j-boxes. Make sure the wires are twisted together.
Twisting conductors together helps stop wire separation.
You could also go thru with a volt meter and check everything on this circuit to narrow down where power stops.
If both outlets are dead, then its likely to be whatever feeds these outlets first.
It aslo helps to know everything that is on this circuit. Some may be hot, while others are not.
Knowledge is Power, but 240v can Keel You!! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
