Old 12-08-2006, 12:52 PM   #1
Doing it myself
Alan's Avatar
Open beam ceiling and running wire...
Whats the best way to run wire out to the middle of an open beam ceiling?
I'm going to install a ceiling fan in order to help lower the heat rather than just losing it out of the ceiling, and also to help circulate throughout the rest of the house. Obviously I can't run a wire through the attic in this area.
The people who lived there before installed a box over the dining area for a chandeleir(SP?) and they just routed a groove in the wood between the beams, tacked the wire down and painted it to match. It looks terrible, so i'll be covering that one with something as well, but I want to do MINE the right way. Any suggestions?
Thanks,
Old 12-08-2006, 01:24 PM   #2
Alan,
If the top of the beam is exposed but not visible, I would run romex cable along the top of the beam. If visibility cannot be avoided then I would use "wiremold"
http://www.wiremold.com/
As possible, connect to a 15 Amp. circuit so that you can use 14-2 cable, which is easier to work with than 12-2, which is mandatory on all branches of a 20 Amp. circuit.
...Christopher
Christopher is offline   Reply With Quote
Old 12-10-2006, 10:14 PM   #3
Doing it myself
Alan's Avatar
Christopher,
Thanks for the advice. I made a home depot run today and got it all in, even painted the wire mold and box brown to match the ceiling. It looks spectacular.
Thanks again!
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Wiring double switch for new ceiling fan toolmanwannabe Electrical 17 11-15-2011 10:34 PM
Mounting Ceiling Fan to Exposed Beam zero1niner Electrical 7 05-05-2009 12:41 PM
running ethernet through attic null_pointer_us Building & Construction 3 05-15-2006 06:08 PM
ok to leave chandelier third wire unconnected? gonzales9 Electrical 5 01-12-2006 09:10 PM
