Ontario Electrical Code Item - Electrical - DIY Chatroom Home Improvement Forum
Old 05-02-2011, 11:22 AM   #1
Rewards Points: 24
ontario electrical code item
Need a code reference on outlets enclosed in cabinets; have a hinged swing out/up appliance platform - mixer etc. normally plugged into outlet at back of cabinet. Appliance is never used unless cabinet door is open and appliance is out in the open. Is outlet OK according to code?
ogbill is offline   Reply With Quote
Old 05-02-2011, 11:46 AM   #2
Electrician
SD515's Avatar
Rewards Points: 504
Don't know about Canada, but in US NEC the outlet is allowed, but cannot be counted as one of the required counter-top receptacles.
Kyle
Old 05-02-2011, 05:50 PM   #3
Electrician
Rewards Points: 760
26-710(h)
a receptacle shall not be placed in a cupboard, cabinet, or similar enclosure EXCEPT
-an intergal part of a factory-built enclousre
-provided for use with a specific type of appliance that is suitable for
installation within the enclosure
-intended for a microwave oven
-intended for a cord connected range hood
-intended for a cord connected combination microwave oven/range hood
So you probably could get away with it by useing exception #2
darren is offline   Reply With Quote
The Following User Says Thank You to darren For This Useful Post:
ogbill (05-03-2011)
Old 05-02-2011, 07:31 PM   #4
joed's Avatar
Rewards Points: 11,592
Sounds like an appliance garage type of setup. Receptacle is permitted inside the garage but it MUST be turned off automatically when the door not fully opened. 26-710(i) (2009 code book)
The Following User Says Thank You to joed For This Useful Post:
ogbill (05-03-2011)
Electrical Code in Chicago!?! moose186 Electrical 37 12-28-2014 01:27 PM
Where to find an online electrical code for Ontario? Red Squirrel Electrical 14 06-26-2014 07:43 AM
Old Bathroom - all electrical on one circuit? how to change? Steve19 Electrical 16 03-14-2011 10:32 AM
Ontario Electrical - potlights at rough in ??? anotherguy2010 Electrical 9 01-04-2011 09:38 PM
[Pics Inside] Unsure what this part does (electrical fireplace switch) rdiggidy Electrical 4 09-07-2009 07:14 PM
