Old 03-19-2010, 11:54 AM   #1
Question
Ontario CE code for kitchen counter outlet height?
Greets everyone. I've searched the site and did not see any clear answer to my questions, so here goes.
I'm installing a new kitchen counter top and would like to relocate existing wall outlets as low as possible for esthetic purposes to hide the appliance wire clutter from the current middle of the wall between counter and upper cabinet. I am starting with fresh drywall on the back-splash wall, so now is the time. Horizontally just above the backsplash would be perfect!
I also want to install a switched outlet under the upper cupboard which will run low voltage under cabinet lights. Can I tap power from the range hood light for this dedicated purpose?
Best regards....
mrgadget is offline   Reply With Quote
Old 03-19-2010, 02:16 PM   #2
joed's Avatar
I don't think there is anything in the code regarding the height of the receptacles above a counter.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 03-19-2010, 02:21 PM   #3
Master Electrician
No more than 20" in the USA.
brric is offline   Reply With Quote
Old 03-20-2010, 09:42 AM   #4
Thanks. I stumbled on a shortened version of the codebook at Home Depot and what I hope for doesn't seem to be an issue.
Old 03-20-2010, 10:20 AM   #5
Electrician
When you say range hood light do you mean a simple range hood or is it a over the range microwave combo. If it is an OTR you can not sure the circuit, if it is a regular range hood then you can share.
darren is offline   Reply With Quote
Old 03-20-2010, 11:19 AM   #6
Regular hood with light and fan only. Thanks.
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
Code for basement ceiling height RDS Building & Construction 3 04-22-2008 11:46 AM
Minimum outlet height? Taipans Electrical 32 03-04-2008 04:31 PM
Code for Outlet Placement in Basement redbandit Electrical 5 01-02-2008 11:13 AM
code for determining retaining wall height mrdol General Discussion 2 11-08-2007 03:47 PM
