Old 05-03-2010, 08:14 AM   #1
Ontario Canada Electrical Code Question?!?
First let me say I love this place - I've been through 2 renos with plenty of help from everyone here. so thanks!
Recently (about a year ago) we moved into a 'Mansor' - style home ... at least that's what someone told me it was called ...
we're doing a number of renovations - while I had the walls opened, I figured I might as well replace the aluminum wiring.
if you look at the picture below, you can see the outlets on the second floor were run on the outside of the 2x4 exterior wall between the roof (instead of drilling through the 2x4's).
If I were to run 14/2 romex, can I do this with copper? staple it to the outside of exterior wall instead of drilling through the 2x4 and running the wire through the wall?
Any info would be appreciated.
Thanks!
Ontario Canada Electrical Code Question?!?-p1060013-w768.jpg   Ontario Canada Electrical Code Question?!?-p1060007-w768.jpg
njchan is offline   Reply With Quote
Old 05-03-2010, 08:30 AM   #2
Just call me Andrew
How tight is that space? I'd just drill holes.
Andrew
secutanudu is offline   Reply With Quote
Old 05-03-2010, 08:57 AM   #3
joed's Avatar
You need a vapor barrier behind that box on the outside wall.
If that outside wall is actually the roof then you can't staple the cable to it. To close to surface, roofing nails could puncture it. You could staple it to the 2x4 running side ways that I see.
Do not PM with questions that can be asked in a forum. I will not respond.
The Following User Says Thank You to joed For This Useful Post:
njchan (05-10-2010)
Old 05-10-2010, 04:04 PM   #4
thanks - for the info - this is the existing/old box. I'm planning on getting these "special" exterior boxes at home depot - that have vapour barrier attached to the back already. I'm guessing you secure the box, put vapour barrier on, then pull the electrical box barrier out through and tuck tape.
hard to explain, but I think it's the right way of doing it ...
Old 05-10-2010, 09:29 PM   #5
It'd be hard to staple in the back of those studs! Either drill holes or run the wire on the horizontal roof rafter!
By the way, you have a mansard roof!
well pump electrical multimeter question tpolk Electrical 21 04-28-2010 11:37 PM
Question about electrical shock chewing cords sljacobs Electrical 12 02-25-2010 10:36 AM
Drainage Code and Question rodg2915 Plumbing 1 03-08-2007 08:24 AM
code question JustJoe Building & Construction 3 01-27-2007 10:06 AM
Electrical receptacle replacement question sherlock Electrical 7 05-20-2005 04:33 PM
