Ontario (Canada) Electrical Code - Electrical - DIY Chatroom Home Improvement Forum
Old 02-24-2013, 08:36 PM   #1
Hello: I have been lurking for some time, but now have a question.
I am considering some work in an upstairs bathroom that requires a dedicated cicuit to be run up from the basement. My house has plaster walls. I am trying to locate the best way to run the wire up 3 floors without significant plaster damage. Outside is not an option.
I do have a 4 inch plumbing waste stack that runs the entire way up inside walls and it would be possible to fish the wire within the walls all the way along side of this stack. Would code permit this?
To be clear I will have a qualified electrician complete the work, I just want to have as much of the ground work done so I know what to expect etc. I don't want someone to come in and start hacking at 3 floors of plaster. I want a plan of action before hand.
Thanks for any help
Scotty
Tequila Scotty is offline   Reply With Quote
Old 02-24-2013, 11:19 PM   #2
joed's Avatar
Rewards Points: 11,982
Code would permit the wire to run beside the stack pipe.
FYI, Code in Ontario does not require a dedicated circuit for a bathroom. It does not prohibit either so you can run the dedicated if you wish.
Old 02-24-2013, 11:28 PM   #3
Thanks for the answer. The cicuit would be for an air bath tub - 15amp.
I'll assume there is no need to secure the wire to the studs then - as it goes down through the walls to the basement.
Thanks again,
Scotty
Old 02-25-2013, 08:25 AM   #4
joed's Avatar
Only needs to be secured where it can be accessed. No need to cut holes to secure it.
Electrical Code in Chicago!?! moose186 Electrical 37 12-28-2014 01:27 PM
Where to find an online electrical code for Ontario? Red Squirrel Electrical 14 06-26-2014 07:43 AM
a few Ontario electrical code questions phdtrucker Electrical 16 12-13-2012 09:04 AM
New Basement Bathroom / Laundry Room Electrical Circuit(s) Rookie11 Electrical 5 12-11-2012 09:52 PM
Ontario Electrical - potlights at rough in ??? anotherguy2010 Electrical 9 01-04-2011 09:38 PM
