Ontario Canada Code Dishwasher Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 04-07-2013, 10:16 PM   #1
Hi
Is there anything in the Ontario Code regarding connecting the dishwasher circuit to the panel when the appliance will be instaled at a later date?
The circuit on the appliance side is finish with the wire coiled inside a JB and terminated with wire nuts [ marretes]
Thank you
T1
tango1 is offline   Reply With Quote
Old 04-07-2013, 10:46 PM   #2
Rewards Points: 31
If i understand the question correctly...that is OK!
Olsy is offline   Reply With Quote
The Following User Says Thank You to Olsy For This Useful Post:
tango1 (04-08-2013)
Old 04-08-2013, 12:17 AM   #3
Always learning...
fetzer85's Avatar
Rewards Points: 262
Picture please?
If the dishwasher is going to be hardwired then I'm not sure why you'd have the wires capped in a junction box. The dishwasher should have a junction box built in the lower front right area behind the kick panel.
If you plan on installing a plug on the dishwasher and powering it from a receptacle below the sink then the wires should be hooked up already.
Maybe I'm missing something? Which is why a picture would help. :-)
fetzer85 is offline   Reply With Quote
The Following User Says Thank You to fetzer85 For This Useful Post:
tango1 (04-08-2013)
Old 04-08-2013, 08:54 AM   #4
joed's Avatar
Rewards Points: 12,028
No problem with a live unused circuit being there as long as all connections are in covered junction boxes.
The Following User Says Thank You to joed For This Useful Post:
tango1 (04-08-2013)
GFCI requirement in Ontario Electrical Safety Code lameon Electrical 15 01-20-2015 07:51 PM
Underground Electrical Conduit in Ontario Canada. A few questions... rrmerlin60 Electrical 3 03-18-2013 11:08 PM
Ontario Canada Electrical Code Q borg Electrical 3 03-04-2013 03:30 AM
Ontario (Canada) Electrical Code Tequila Scotty Electrical 3 02-25-2013 08:25 AM
Dishwasher connection and wiring, oh boy! Bigplanz Electrical 18 06-15-2011 10:52 PM
