Old 07-15-2012, 06:55 PM   #1
Question
Only one room testing as Not Grounded?
Another question already...
I have a house built in 1966. All of the outlets upstairs have metal boxes with no visible ground wire. A receptacle tester shows all of the outlets as grounded except for the living room.
So I'm wondering, what might the reason be for the living room not testing as grounded? When I touch a "pig-tail" tester to the hot wire and directly to the box, it lights up, so perhaps the ground is too weak for the receptacle tester to detect it? The outlets in the other rooms are the same as the ones in the living room, so I'm confused as to what is making the difference.
I know there are numerous possibilities here, but I'd like to hear your theories on what may be going on.
brad34 is offline   Reply With Quote
Old 07-15-2012, 07:39 PM   #2
E2 Electrician
stickboy1375's Avatar
First off, what wiring method is installed? Most likely, somewhere along the way, you have a junction box that contains shoddy connections.
Old 07-15-2012, 08:29 PM   #3
Type TW..it looks like the first floor is through conduit.
Old 07-15-2012, 08:49 PM   #4
E2 Electrician
If its old AC wiring and it doesn't contain a bonding strip within, then all you can do is GFCI protect the circuit install grounded receptacles....
Old 07-16-2012, 01:39 PM   #5
It was a dark and stormy
Yoyizit's Avatar
Yes, a high resistance ground, maybe due to rust.
More than 1/2 ohm between your neutral and ground terminals measured at the outlet is probably too much.
If you buy a real multimeter it'll pay for itself the first time you use it to correctly diagnose a problem.
Old 07-16-2012, 03:50 PM   #6
Licensed Electrician
jrclen's Avatar
Maybe a conduit connection is corroded or no longer connected in that room.
John
jrclen is offline   Reply With Quote
Insulating a cold/well room? Lynch Building & Construction 22 02-09-2013 08:51 AM
Bathroom to Laundry Room to Bathroom bcatanz10 Remodeling 2 10-10-2011 10:45 PM
Vapor Barrier on elevated 4 season room Indyc0lt Insulation 3 09-15-2011 02:41 PM
advice/Help on non-permitted bonus room? Orange_County General Discussion 43 06-11-2010 06:06 PM
What Makes A Room A Bedroom? HowToGuy Remodeling 11 02-26-2010 03:44 PM
